LED brake light upgrade...
Posted 31 May 2012 - 07:55 PM
Plug in LED's in place of the oem bulbs dont cut it due to not enough light spread and it looks shit.
Custom FTW.
PCB (printed circuit board), 20 super bright red LEDS and a little electronic know how. :wink:
Im running them in 4 banks of 5 LED's in parrallel (5 LEDS left to fit, Jaycar ran out), each LED needs 2.1V for optimum output. 5 x 2.1 = 10.5V. Average car ouput when running is 13.8V. To take care of the extra 3.3V, a 110 Ohm resistor on the end of each bank is fitted in series so they run at optimum level and maximum life.
Theyre bright.
OEM 4 bulb setup...
New LED setup... (one bank left to solder in)
Mounted with test leads...
Yep, theyre bright....
Posted 31 May 2012 - 08:00 PM
Nice one!
Posted 31 May 2012 - 08:02 PM
Posted 31 May 2012 - 08:03 PM
Is that a power board with a temp controlled soldering iron and regulated power supply?????
Posted 31 May 2012 - 08:04 PM
Has a variac for both AC and DC supplies, plus all the other usual stuff. Its handy.
The soldering iron on it is SHIT!
Posted 31 May 2012 - 08:15 PM
Tried to scope it out. But can't work it out
Posted 31 May 2012 - 08:17 PM
Posted 31 May 2012 - 08:19 PM
Posted 31 May 2012 - 09:04 PM
Posted 31 May 2012 - 11:12 PM
Posted 01 June 2012 - 07:33 AM
Nah... Clever
Nice work Mark
Posted 01 June 2012 - 10:02 AM
Looks like one of those $15 tricky dicky specials.The soldering iron on it is SHIT!
Posted 01 June 2012 - 11:09 AM
Posted 01 June 2012 - 05:27 PM
but they are not centred mark,sorry just read it again and noticed there is one more bank to go in
Yeh, Jaycar had no more LED's. I took their last 15. They'll have more in on Tuesday so I can finish it off then.
Posted 01 June 2012 - 08:32 PM
Posted 04 June 2012 - 06:44 PM
Thats for one bank of LED's. This is replicated 4 times.
Posted 04 June 2012 - 08:52 PM
Posted 04 June 2012 - 09:03 PM
The 110 Ohm resistor drops the 3.3V that makes up 13.8V that a car runs at on average. A little higher or lower voltage wont be a problem.
