Power steering pump maybe?..
Posted 12 June 2012 - 11:21 AM
The other day, after a cold nite in the bush, when i started the car in the morning, it made a whine noise, like an electric car sound.
when the car was stationary, and the wheel turned left and right you could hear the pitch of the noise change like it was the power steering pump under load.
but after 6-10 k's the noise went away never to return for the rest of the trip home (4hrs)
this morning after a wet and cold night in sydney, the noise done the same thing this morning and after 10 k's it went away.
the power steering fluid is topped up but smelt funny, not sure how it supposed to smell tho,
the whole time the steering feedback has felt normal.
any ideas ?
Posted 12 June 2012 - 12:02 PM
tighten the belt
Posted 12 June 2012 - 01:46 PM
change the belt
fixed.
Posted 12 June 2012 - 01:48 PM
If it smells burnt or it looks fairly black (should be a bright red, ATF colour), change it.
Bleed it properly, go for abit of a drive, then change it and bleed it again.
Posted 12 June 2012 - 02:40 PM
in saying that, it does sound belt ish.
Posted 12 June 2012 - 04:54 PM
Shazza
Posted 12 June 2012 - 05:00 PM
At full lock it was a very loud whining noise and whilst driving slow and tight corners the steering would get very very heavy intermittently.
It's was about $600 to get it removed sent away and rebuilt and installed again
Posted 12 June 2012 - 06:24 PM
most cases with the sound is either u hav air bubbles in the system or the atf fluid needs to be changed
Posted 12 June 2012 - 07:16 PM
Posted 12 June 2012 - 09:30 PM
If you've topped it up, you might need to bleed some bubbles out which is the easiest thing in the world - top it up, leave the lid off and turn the wheel from full lock to full lock a few times (gently, don't smash it into the bump stops). Done. Check the fluid level and top it up if need be.
Posted 13 June 2012 - 12:50 PM
if Hoff had has done at 146K, mines @141K, maybe its just around the corner.
how do bubbles get into the sytem?
legends guys
Posted 13 June 2012 - 12:58 PM
Grab a short length of garden hose and (when it makes the noise) use it to listen around the belt/pump area and see if you can pipoint where it is coming from.
