Subaru Outback H6 engine noise
Posted 29 August 2012 - 05:56 PM
so turns out that my new h6 wasnt as much of a bargin as i thought at first...
basically there is a slight knocking on the passengers side head, firstly after some research apparently the h6 engine has issues with the timing tensioners failing over time so that was my first diagnosis... Took the car to see BenTZ today and he said its too far back in the engine it must be a stuck and or sticking lifter and advised an oil change to a thicker oil (20w50). bought 6litres of oil, drained the oil and topped it up, still head is ticking and then when i bottled the old oil there is less than 5.5Litres that came out...!!! and that was after i changed the oil 4days ago...!!!
so its quite clear that i have an issue if i burn 0.5 of a litre of oil in 4days...
can anyone point me in a direction, i have posted a video on youtube that is linked below of the sound, for refrence the as the revs are increased in the car the noise increases in speed...
help please..!
Posted 29 August 2012 - 08:35 PM
you could try some engine flush and a fresh lot of 10/40 ive never herd that sound before??? verry weird
also could be a valve riding?
Posted 29 August 2012 - 08:39 PM
Posted 29 August 2012 - 08:42 PM
Posted 29 August 2012 - 08:56 PM
I usually dont believe in all that stuff but i have use these before and they seem to work.
Posted 29 August 2012 - 09:23 PM
Posted 29 August 2012 - 09:24 PM
Posted 29 August 2012 - 09:50 PM
its a h6 outback yes?
Nah the title says differently
Posted 29 August 2012 - 10:01 PM
Posted 29 August 2012 - 10:07 PM
No good Scotty, thats sort of what my engine sounded like when i changed an exhaust part over on my car… It was a leaking gasket.
Posted 29 August 2012 - 10:35 PM
Try unplugging the injectors one by one (if you can get to the plugs) and see if the noise changes when a cylinder loses it's power stroke.
This will eliminate anything deeper inside the engine, leaving just the valve train.
Posted 29 August 2012 - 10:44 PM
0415 522 512
Posted 29 August 2012 - 11:07 PM
To use that much there's got to be bottom end stuff going on IMHO.
Posted 31 August 2012 - 04:58 PM
Posted 11 September 2012 - 08:41 PM
Posted 11 September 2012 - 09:12 PM
Posted 11 September 2012 - 09:48 PM
will update when i get a call with a diagnosis
not looking like fun though
Posted 29 October 2012 - 05:09 PM
a full VRS (no idea what this stands for) was done on the engine, all valve seals were changed. my only guess adn what Ben (93tzlegacy) have possibly thought it might have been a slight blockage somewhere.
apologies i cant provide any more info
Posted 29 October 2012 - 05:16 PM
2008 Subaru Legacy 3.0 Spec S/W - Sunroof, leather, SI Drive, Xenons, 18' GTB Alloys, Quartz Grey
2000 Subaru Lancaster6 3.0 S/W - Beige Suede Interior, HID Headlamps, Pearl White
1993 Subaru Impreza S-Edition S/W - 5-Speed Manual, Blue, 1.8L EJ18 - Sold April '13
2001 Subaru Lancaster6 3.0 S/W - Sold May '12
1999 Subaru Legacy B4 2.0 - Sold Jan '11
Posted 29 October 2012 - 05:50 PM
alright so i got the engine back and put it back in the car, and runs perfectly, the guy who disassembled it and cleaned it could not find anything wrong with it.
A VRS kit is a valve re-seal kit.
At least it's all good now! Can't wait to see this car in person.
