redline shockproof oil
Posted 11 November 2012 - 11:19 AM
should i go superlight or lightweight ? 75/90 or 75/140?
im leaning towards the lightweight rather then the superlight.
Posted 11 November 2012 - 11:32 AM
It's a little expensive. But, No oil compares to it. Only downside is it's the only oil you will be able to use in the box in future.
The cheapest I've seen it is on ebay: http://www.ebay.com....#ht_1466wt_1163
Highly recommend it, Give it a go.
Posted 11 November 2012 - 12:10 PM
Ive seen lots of horror stories of gummed up gearboxes etc
NEO is the bomb diggidy! I wont use anything else now
Posted 11 November 2012 - 12:31 PM
I've never flushed either, Just taken drain plug out and let it sit for a while.
Neo oil is also good.
Posted 11 November 2012 - 12:34 PM
Posted 11 November 2012 - 12:40 PM
that ebay pricing seems to be similar to http://www.performan...20pricelist.htm but he sells in the larger quantity by the looks.
Posted 11 November 2012 - 12:41 PM
Posted 11 November 2012 - 12:44 PM
i guess just draining the old oil wouldnt suffice and maybe a atf cleaner or similar is needed?
Posted 11 November 2012 - 07:43 PM
Posted 11 November 2012 - 08:00 PM
do you have a link alex?
EDIT: is this the one? NEO RPS 75W90HD
Posted 11 November 2012 - 09:26 PM
I use this as recommended by MSR
this is in my slightly abused 6 speed and diffs though...
best oil ive had in it so far!
Also gen3 20psi
Posted 11 November 2012 - 09:40 PM
Also been using this! It's good shiz
Posted 11 November 2012 - 09:49 PM
Wonder if theres much difference between the two? Ill have to talk to Michael next time i see him
Posted 11 November 2012 - 10:07 PM
Posted 12 November 2012 - 04:08 PM
now im confused lol.
how does the NEO RPS 75W90HD go on slightly worn synchros, does it help.
im moreso wanting to try neo as i havent heard any negatives about gabox gumming from neo users.
Posted 12 November 2012 - 04:49 PM
just had a thought, the issue has only really presented itself when i changed from an old worn droplink setup at the rear to a new clink setup.
perhaps the gb mounts are worn and that could be the noise im hearing , ill pop my head under soon or get the mech to see when i get the turbo installed.
what are the symptoms of a work gearbox mount?
Posted 12 November 2012 - 07:00 PM
just emailed michael and he recommended the lightweight over the NEO RPS 75W90HD
Posted 13 November 2012 - 07:40 AM
I've heard by a reputable Subaru gearbox specialist to explicitly avoid using the redline stuff, as it gums up over time (50k kms springs to mind), blocks the oil galleries, and starves the gears and bearings of oil.
Matt & Scott - where did you score your neo from? Im still running Nulon from the initial conversion, and I'd like to upgrade the oil now
Posted 13 November 2012 - 07:58 AM
6SPD - Redline bad.
Posted 13 November 2012 - 02:17 PM
Hey Alex got mine from this bloke, from memory his name is Gerardlawls
http://www.gccorp.com.au
