Any reason why I'm getting oil coming out of my timing belt cover? I can see that the gasket is broken but I thought this area was dry?
Oil leak from timing belt cover?
Started by HowFarToAsgaard, Mar 19 2013 12:20 PM
5 replies to this topic
Posted 19 March 2013 - 12:20 PM
Posted 19 March 2013 - 12:26 PM
Cam and or crank seals are possibly leaking
95 Gen 2 gx series 1 with rx body kit built 207 on v2 sti heads, running gear, FMIC,twisted ATP GTX3076 Turbo setup
Posted 19 March 2013 - 02:10 PM
The leak is right at the top of the gasket close to the harmonic balancer.
Also if there's oil in there is that a bad problem for driving?
Posted 19 March 2013 - 02:15 PM
It would only be seeping out... Check ur oil levels regularly... Mines been leaking for the last 10/15K... Need to get around to changing mine or ill just wait til timing belt change in 20K
Posted 19 March 2013 - 02:18 PM
But getting oil over the belt is this a bad thing?
Posted 02 April 2013 - 07:08 AM
I would assume it is bad, but I don't think it would slip like a acc. belt. Not sure if it would ruin the belt at all having oil on it?
Maybe open it up and check inside to see if the oil is leaking on the belt.
