B4 timing belt kit
Posted 17 April 2013 - 01:27 PM
Also dose anyone know what is ment to come in the kit it self? I think I'm goring to need a new tensioner as well. Subaru quoted me $1200 including parts and labour and said the tensioner is leaking because there's oil coming out of the timing cove just above the harmonic balancer.
Also is replacing the Tensioner bracket recommended?
Posted 18 April 2013 - 03:02 AM
wat usally comes in kit well one i bought came with everthing water pump timing belt all the pulleys and the tensioner
and i got it for 300 bucks
Slower Then The Rest
50.CYA
YAMAHA R3 2015
Posted 18 April 2013 - 06:58 AM
His kits are $450 (maybe more for the turbo models) genuine Subaru.
This includes belt, oil crank seal, idlers, and tensioner.
You'll also wanna change:
water pump
Water pump gasket
Thermostat
Thermostat seal
Cam seals
Posted 18 April 2013 - 07:11 AM
Chris would be the cheapest around
Posted 18 April 2013 - 07:21 AM
Parts guy said there very hard
Posted 18 April 2013 - 08:03 AM
Top bloke. Great prices. Genuine products.
Posted 18 April 2013 - 08:39 AM
How hard is it to do the water pump and cam seals?
Its more tedious than anything.
Follow the service manual
Posted 18 April 2013 - 09:05 AM
Parts guy is a retard then.
If you can do the timing belt you can undo the 6 or 7 10mm bolts that hold the water pump on.
Also if you can change the oil crank seal you can change the cam seals cause their the same.
+1 for the service manual! Step by step instructions that tell you exactly what to do.
Posted 18 April 2013 - 09:09 AM
Posted 18 April 2013 - 09:18 AM
When the water pump comes out you'll loose the coolant anyway
Not to mention i think its more 'ing around to pull the fans off compared to the radiator off.
Posted 18 April 2013 - 09:32 AM
Posted 18 April 2013 - 05:31 PM
