Removing B4 PCV valve
Posted 06 May 2013 - 04:24 PM
Got an idea where it is, some where under the throttle body?
If so do i need to remove the throttle body to gain access or is there other ways to it?
Posted 06 May 2013 - 05:14 PM
Ive taken the liberty (no pun intended) of even searching the link for u which took 1 minute... Another spoon fed session
http://www.subyclub....rkshop-manuals/
Posted 06 May 2013 - 08:12 PM
Posted 06 May 2013 - 08:20 PM
Why are you removing it?
Posted 06 May 2013 - 08:23 PM
The PCV valve itself will be threaded into the bottom of the manifold, pointing towards the firewall. Its a simple ball bearing valve. Also make sure not to drop anything down the larger crankcase vent port.
Posted 06 May 2013 - 08:43 PM
Thanks Jimbo, awesome advice thanks!
Iv got alota oil build up coming around that area, and my air filter is a bit dirty being its 5 months old. My idle is pretty rough so im hoping that its just a block PCV.
Posted 06 May 2013 - 08:48 PM
Posted 10 May 2013 - 02:39 PM
I even used that parts website opposedforces.com and even they don't have a listing for it?
I can find one for the RX but unsure if its the same fit?
Posted 14 June 2013 - 08:20 PM
Posted 12 November 2013 - 10:05 AM
Mate I'm having same issue finding Suby part number for PCV, did u find one after all or even a similar model EJ one that fits?
Nah man, I couldn't find one in the end. My brother suggested to remove it all together but I wasent sure on what needed to be done to do such a thing so it got it ultra sonic cleaned and put it back in. Don't think any other model will fit being that it's nothing like any other model that iv seen
Posted 12 November 2013 - 10:11 AM
Posted 12 November 2013 - 05:34 PM
it is but its not listed, its number 12
iv gone to every Subaru parts shop and they have the same issue its not listed but its in the diagram and they cant explain it either
any other model yeh but the B4 is the only one they cant find
not even Repco can even find one
Posted 12 November 2013 - 06:02 PM
Can't see the need to replace it, as long as it's been cleaned out it should be sweet. It's just a small case with a bearing that moves depending on the intake pressure. If it's still presenting a similar problem, after the cleaning, i would say it's probably something else.
If your piston rings are getting tired, excess pressure in the crank case and heads can make a mess of your emissions junk. I once had a ring gone so bad, my atmo BOV used to shoot oil into the chassis rail. Double check all your lines and fittings, and for extra security get yourself a compression test done.
Whatever you do, avoid leaving the head and crank case breathers open to atmo. I would also suggest rigging up yourself a catch can.
Posted 12 November 2013 - 06:27 PM
also just clean these things out in a jar of fuel.. give it a shake and all good..
Also.. im pretty sure they are all the same.. just get same as an RX one.. its a pretty simple device as mentioned.. Case, spring, ball bearing.
