Best ej block for a monster turbo build?
Posted 21 August 2013 - 03:03 PM
Everyone's opinion on this would be great.
Cheers, Joe
Posted 21 August 2013 - 03:06 PM
Posted 21 August 2013 - 04:54 PM
Posted 21 August 2013 - 05:02 PM
read this thread before you even consider it.
http://www.subyclub....sti-conversion/
If you still crazy enough to consider it talk to vicelore first hand. no offence to vicelore he has one sweet ride but for what he could bought for that money is crazy.
Posted 21 August 2013 - 05:10 PM
Posted 21 August 2013 - 05:14 PM
Buy Jakes, $16000 and its already built ready to go.
Was going to say, buy Jakes car. It's already done and still has potential. I don't think its fully tuned yet either from what I've read.
Posted 21 August 2013 - 05:15 PM
So 300kwatw?
Big problem with a ej257 block is the bores are very thin causing alot of bore flex. This in turn causes head gasket failure, uneven bore wear and even total failure of the bore. The use of e85 can off set this a fair bit but for that power range your looking at dart inserts and a closed deck (AKA $$$$$).
Have you thought about a ej22 block? Put a gt35r twist mount on a forged ej22 with sti heads/cams with e85 and your safe to boost it to 20psi+ and not stress. If you realy want you can fit a ej257 crank to the ej22 block!
Ej257 are nice motors but you need coin the keep them safe over 250kw.
Posted 21 August 2013 - 05:30 PM
Posted 21 August 2013 - 05:31 PM
As Cameron said... Look at what vice went through. . But also if you are going to do work yourself. Things can be cheaper..
Vice was in a spot of not knowing a heap about subies and engine building. A very expensive lesson learnt though..
Buying power vs building power.
Remember the 3 key factors. Cheap Reliable. Fast. You can choose 2 and only 2.
Posted 21 August 2013 - 05:35 PM
i would buy this
http://www.ebay.com....=item43be6bab30
http://www.subyclub....ty-wagon-turbo/
convert the interior to series 2 ie black and put an rx/gtb kit on it. fix the issues and when/if you blow it up chase some power with a build ej22.
i think this is an absolute bargin
Posted 21 August 2013 - 08:35 PM
Posted 22 August 2013 - 04:44 AM
I'm pretty sure JRod has a monster EJ already done he is selling?
Quoted for the win!!!11
I have a short motor still wrapped in plastic. 11ty bazillion times stronger than a bloody ej257. Wheres my for sale thread......
As soon as i mentioned 300kw I was in trouble
Posted 22 August 2013 - 06:39 AM
Buy mine!!!! i have it running at 270kW @ 18psi but was making 300kW @ 21 psi when i bought it,
$16000 with REGO + RWC
BRISBANE
Posted 22 August 2013 - 10:11 AM
Looks amazing but I like the shape of the gen 2 betterBuy mine!!!! i have it running at 270kW @ 18psi but was making 300kW @ 21 psi when i bought it,
BRISBANE
Posted 22 August 2013 - 10:19 AM
Saw your sale thread, seems abit expensive though :/Quoted for the win!!!11
I can get a closed deck shortblock ej257 with the following features:
Reconditioned Block Halves
Closed Deck Process to Block Halves
New 09+ EJ257 Nitrated Crankshaft
New CP Forged Pistons
New CP Rings
New Manley H-Beam Forged Rods
New ACL Race Bearings
For $5500 and im sure that'd be able to hold some decent power?
Posted 22 August 2013 - 10:48 AM
Agreed, the only thing i would add to that is some sleeves.
If your close decking, and chasing big power do it now, its not expensive, and gives headroom.
Posted 22 August 2013 - 01:20 PM
Posted 22 August 2013 - 02:59 PM
The v4 STI heads are fine.
PS1000 with an ethanol sensor. Some ID2000 top feeds and a twin scroll housing on a GT35R would put the icing on the cake.
Posted 22 August 2013 - 03:19 PM
