Hi all,
I've been having a strange sound come from the bottom of my '03 AUDM B4 and was hoping someone could point me in the right direction. I've taken it to the mechanic and i didn't have a chance to properly describe it. He took it for a drive and said he could hear the cat rattling a bit. He chucked it up on the hoist and gave the cat a bit of a bang, I could hear the rattling but it didn't sound like the same sound I've been hearing. This lead me to believe that he was hearing an entirely different sound. I thought that perhaps this was the underlying issue anyway so I didn't really object. I have a list of my findings below for analysis
What does it sound like?
It sounds like a short, hollow "tink" sound. Not unlike what you would hear if you flicked a wide pipe made from thin metal.
Where is it coming from?
It seems to come from underneath the car, somewhere under the driver's seat. I can feel the split second vibration caused by it on the accelerator/brake.
How often does it occur?
It is just a single sound that occurs, then may not occur again anywhere from another second, to another few minutes, to potentially an hour or so (next time I drive the car). It is not a continuous sound that happens relative to speed/revs.
When does it occur?
This problem is very inconsistent as sometimes I won't hear it again for days, but it seems to be affected by the cold. I've noticed lately that as it's been very cold/rainy in Adelaide it has been occurring much more often. Once the engine has warmed up it doesn't seem to happen quite as frequently and the noise it makes when it does is quieter. Sometimes after it's warmed up the sound stops all together. I have also noticed it happen when the car was off - I had turned it off for probably 15-20 mins then got in and I heard it before I'd even started the car.
I'm not well versed in diagnosing mechanical issues, but I'm wondering if bits of broken cat are occasionally arranging themselves in a way which restricts the airflow through the exhaust (near under the seat) causing a pressure buildup. The sound I am hearing could be this pressure build up releasing, causing the hollow tink sound in the exhaust. This could also be affected by the outside air temperature and engine temps. Not sure if this situation is even possible but it's the only thing I could come up with given the symptoms.
TL;DR - Car periodically making hollow "tink" sound underneath drivers seat area. Happens more in colder weather and when engine not warmed up.
Look forward to hearing some theories
