Hi Folks.
New to the forum so here goes.. I've trolled the net and looked at posts here for info, I'm guessing that the answer is here already and posted so I may be repeating questions.
1) recently purchased a GC8 11/99 VIN numbers shows it to be a WRX but it's not turbo'd "it's the RX version" same blue and rear wings ETc Etc.
2) Eng and vin combination No's shows it to be a EJ205. (comp 8:1) Low for a N/A motor ? I have checked various sites to decipher the codes but a little confusing.
so here's the questions
1) Did Suby's come out with a SOHC WRX turbo version or where they only DOHC.
2) Handling improvements I have found out the car seems to be a little low in the back end (could be age and usage on existing shocks) whats a good set of shocks for the car and what is the avg ride height for a stock car Measured.
3) Steering........ I feel the car's steering could be tightened up...... AWD and power steer makes a great combination but I reckon this could be tuned a little better has anyone done much with this ??
4) Air intake... I have seen some posts where the owners are using the Large K&N Pods down near the front drivers side, is there much benefit or is more bling than Zing, I''m aware better air intake is good.... being old school we used to open up the existing air intakes for additional air then beefed up the filters inside the original filter boxes.
5) Peformance tweaks.. okay I have spoken to the Experts all say there's not to much that can be done to the GC8 N/A and the modules are a waste of space and money so the obvious things are cam's, better Exhaust, and air intake.
I'll probably have heaps more questions as I learn about the car but these may be a good start.
Pats (the passenger and mechanic)
