Indicators/Hazards have failed - HELP!
45 replies to this topic
#1 Samwise
  • 8434 posts
Posted 05 September 2013 - 11:59 AM
Hey guys,
As title says..
I've thrown bulbs, fuses, relays and even a new combo switch (thanks again Bosskong) at them and nothing is working..
However they still flash when locking/unlocking the car.
I've done an impedance test on the switches to check both were working fine.
Multimeter tests show I'm getting 6v from the wire that goes to the module, but 0v from the fusebox wires.
Relay is working, I can hear it clicking when I use the indicators/hazards..
Dash has not been out recently..
Would anyone have any idea what could be going on?
I really need to drive my car, but don't wanna risk getting pulled up for not indicating..
Cheers!
#2 RX25SE
Posted 05 September 2013 - 12:14 PM
Hazard switch.
Combo feeds hazards before the lamps.
Most cars the indicators won't work if the hazard switch is unplugged.
Alarm would be wired in after the hazard switch.
#3 Samwise
  • 8434 posts
Hazard switch.
It shouldn't be unplugged... I haven't pulled the dash out.
So, the hazard switch has failed?
#4 RX25SE
Posted 05 September 2013 - 12:16 PM
That would be my guess.
#5 Samwise
  • 8434 posts
Posted 05 September 2013 - 12:20 PM
Okay.
I should've also mentioned that it failed over time, sorry. Would it do be that too? The switch just failed over time?
I.e. I had indicators for about 50% for a little while and then bam! All gone..
#6 vicelore
vicelore
  • 1579 posts
Posted 05 September 2013 - 12:26 PM
+1 on the hazard switch.. I had that happen after pulling out my dash.
#7 SAV84C
SAV84C
  • 3480 posts
Posted 05 September 2013 - 12:27 PM
Press it and find out lol
#8 Zac
Yo Sam, maybe your hazard switch was on its way out while the indicators were failing over time, so your hazards were intermittently working for a while... and then died.
#9 Samwise
  • 8434 posts
Posted 05 September 2013 - 12:29 PM
The relay clicks when I press it. But nothing else happens..
I haven't been behind my dash though. That's the funny thing..
#10 RX25SE
Posted 05 September 2013 - 12:39 PM
This may be the flasher unit has failed.
As in it wont cycle.
#11 Samwise
  • 8434 posts
Posted 05 September 2013 - 01:11 PM
Checked the switch, it's plugged in fine haha.
Will do an impedance test.
Do you mean the Hazard / turn signal module?
#12 Samwise
  • 8434 posts
Posted 05 September 2013 - 03:06 PM
Anyone know where the unit/module is located?
#13 RX25SE
Posted 05 September 2013 - 03:56 PM
In a Gen IV its under the dash, next to the fuse box and its a beige colored box with about 8 wires. Not accessible through the fuse panel cover.
You have a Gen IV right?
RIGHT?
#14 Samwise
  • 8434 posts
Posted 05 September 2013 - 03:58 PM
RIGHT?
WRONG!
Go pull your Gen 3 apart and tell me where :P
#15 RX25SE
Posted 05 September 2013 - 04:09 PM
Go pull YOURS apart and tell ME where it is.
I looked in the Gen3 w/shop manual. Tells me it has 3 wires but not the location.
IIRC it will be near the fuse box. They usually have 'turn module' or '4x21w' or even 'made in Japan' on them.
#16 Samwise
  • 8434 posts
Posted 05 September 2013 - 04:24 PM
That's what I'm doing!
I know. It's useless for this.
I'm trying to listen for the clicking .. but it's hard when you gotta do it manually.
#17 Samwise
  • 8434 posts
Posted 05 September 2013 - 06:00 PM
Nothing. Dash is half apart and I'm having no luck...
#18 bobbyjimmy
bobbyjimmy
  • 1287 posts
Posted 05 September 2013 - 07:04 PM
It's on top of the steering column to the left hand side - PITA to get too.
#19 Samwise
  • 8434 posts
Posted 05 September 2013 - 07:31 PM
Thanks.
I thought I could hear it around there, but couldn't see anything..
#20 vicelore
vicelore
  • 1579 posts
Posted 06 September 2013 - 10:51 AM
Getting to that is a super pain.. cluster out etc..
