Has anyone done this conversion?
what tail shaft was used?
I have everything bolted in but the tail shaft is too short at both ends from centre bearing!
03 JDM STI was the donor car
cheers in advance for any help!
Posted 22 February 2014 - 06:22 PM
Posted 22 February 2014 - 06:30 PM
Pretty sure you use a gen 3 auto tailshaft.
Posted 22 February 2014 - 06:35 PM
deff. need a gen 3 auto shaft mate , i have one in ingleburn $200. thanks, Ben.
0415 522 512
Posted 23 February 2014 - 12:03 AM
my standard b4 tailshaft female spline didn't fit the output shaft of the 6 speed. i even tried a bug eye wrx yoke! NO CIGAR
03 JDM STI tails haft too short at both ends from the centre bearing.
585mm from end of out put shaft of G/B to centre of bolt hole of centre bearing
911mm from centre line of bolt hole for centre bearing to face of diff flange
and diff flange holes are apron 10mm wider than standard wrx/B4 holes.
Posted 23 February 2014 - 12:09 AM
if it fits no mods required i will take it.
when are you available?
Posted 24 February 2014 - 08:04 AM
Do the auto's have bushes like the MT ones?
Or bolt straight to the floor?
