Engine issues please help ( electrical/sensor)
4 replies to this topic
#1 DARNSKi
DARNSKi
  • 24 posts
  • Interests:custom fabrications, metal engineering, and spray painting
Posted 03 March 2014 - 08:39 AM
Hey got a 1995 subaru GX wagon phase2 engine 2,2L ok my car runs sweet here n there I drive it to work everyday winter and summer no problems.
When I drive up a steep hill and get to the top and then stop or stop at traffic lights my car all of a sudden has power and starts to idle ruff the tone of the engine goes deeper check engine light come on and eventually I have to pull over and turn of the car this problem also happens when I open her up a little driving in higher rpm then usual what could be the problem????
I've tried eliminating factors that contribute to this
Fuel service, spark plugs, leads coils , sensors maf,tps,cas,ips,eks
Like I said car drives perfect until a climb a hill and get engine problems has anyone had this before cheers
I have
#2 Morgan
Posted 03 March 2014 - 09:23 AM
Have you checked the code/s?
#3 DARNSKi
DARNSKi
  • 24 posts
Posted 03 March 2014 - 11:21 AM
Nope as the check engine light will come on only when this occurs then when I turn it off it goes away if I plug it in with a scanner with out the check engine light on will the code still show up ???
#4 Robert
  • 9,419 posts
Posted 03 March 2014 - 11:34 AM
Depending on the scanner, you go into history codes.
It shows the codes that came up between the last ecu reset and now
#5 allpaw4
allpaw4
    Chief Sparky
  • 2,164 posts
Posted 03 March 2014 - 12:28 PM
Instead of turning it off and restarting the engine, make it do it several times on the one engine start. That should cause it to actually log a code rather than just tell you there's a problem.
