As per the title, I need to buy a set of replacement cam gears for my EJ208 (Rev D BE5).
Question is ... should I go aftermarket adjustable, or just try and source an original set?
Does anybody on here have experience with aftermarket ones on this motor, and if so, what brand / model?
I'm using the standard ECU for this build, so from a cost vs benefit perspective, would I be better off just getting a stock set?
