Help : Ecutek Dash Monitor
Posted 14 March 2014 - 09:36 AM
Does anybody know the wiring for a Ecutek Delta Dash Monitor ??
I need to know the wiring for Relay, Power and OBDII...
If you have the entire diagram to email or take a photo of it would be perfect..!
Thanks gents...and gentettes...
Posted 14 March 2014 - 10:19 AM
I dont think anyone here is running the delta dash and I dont think it is a simple process of wiring for relay/power/obd..
https://www.mrtperfo...-in-car-kit.pdf
Have you tried the ecutek website for a manual?
http://www.ecutek.co...dash/in-car-kit
http://www.ecutek.co.../downloads-4015
Posted 14 March 2014 - 12:34 PM
Posted 14 March 2014 - 01:56 PM
That MRT link shows it being installed in a B4. Hmm, I might have to look into one of these units.
Depending on exactly how much data you want/need, for the money there are better display/monitoring units available now imo. Those Ecutek units are getting pretty old now (I don’t think Ecutek even make them any more do they?).
Posted 14 March 2014 - 02:00 PM
Aek, do you have a contact for that ECUDataScan bloke? Has he stopped producing them?
I need a new cable.
Posted 14 March 2014 - 02:32 PM
I need a new cable.
pm sent
Posted 14 March 2014 - 02:52 PM
Delta Dash $1173
Posted 14 March 2014 - 03:04 PM
Haha that works so well because your name is Tim.
Posted 14 March 2014 - 03:38 PM
Posted 14 March 2014 - 03:40 PM
I'm only asking cause I managed to come across one but someone has cut the cables
Posted 14 March 2014 - 03:46 PM
From the manual:
"Route the cable behind the dash to the OBDII
connector and plug it in. No further wiring is
required."
Posted 14 March 2014 - 04:15 PM
pretty sure i saw that for sale some where recently (ebay or rexnet etc??). it was probably wired into a pre obd2 car so has been chopped.
Posted 15 March 2014 - 03:29 PM
What has been cut? Was it the OBD cable that plugs into the OBD port on the car?
From the manual:
required."
Yeah, the obd had been cut.
Normally I would just match colour to colour but wanted to double check first as it splits to different modules and boards inside the unit. (Power, relay and 2 boards)
Guess I'll just have to give it a crack
...Fingers crossed...
Posted 15 March 2014 - 03:47 PM
Posted 16 March 2014 - 05:18 AM
If you have both ends of the cut cable I see no issues with splicing like for like. Companies dont change wire colours halfway down a cable. Splice all of them though, not just the ones you can see being used.
Posted 16 March 2014 - 03:30 PM
thats the bit I'm unsure about...
...as you see only 3 of 6 obd wires actually come out of the cable (where are the other 3 I can see in the cut ?
... And what's with the black box with the white cable coming out of it.????
Posted 16 March 2014 - 04:11 PM
Hmmm... MRT time I think. Just dont let them convince you that you need a whole new setup.
