Looking into having a Air Oil cooler on the Lib..
Wondering if anyone has first hand experience installing one and what they used.
I currently have the Standard STI Cooling plate that uses the Coolant.
I have had some high temps on track and want to go the route of installing a small 9bar? Oil Cooler..
My main questions are..
What pressures will it need to withstand?
Will having near on 2 meters of extra Oil line effect the oil pressures?
Is a Thermostat for the oil cooler a good idea? aka, will running the car in the snow with the cooler cause the oil to be too cold?
My Preliminary thoughts are to run the Cooler in the lower dam of the front bar.
Running the lines around the side of the radiator on the Drivers side and into where filter is and having them mounted up on the chassis rail.
Full Braided lines and Heat Shielding
Just after some Thoughts and discussion on the topic.
