hey everyone
has anyone installed pipes in a gen 2 for cooling brakes ? or know if its possable without loosing my stock fog lights
Posted 07 May 2014 - 08:51 PM
Because race car?
I cant see it being required on a Gen2 Outback.
Posted 07 May 2014 - 09:08 PM
+1
Why not just upgrade your rotors/whole setup? be a lot less stuff around than running ducting.
Posted 07 May 2014 - 09:59 PM
Posted 07 May 2014 - 10:10 PM
Did they over heat or just heat up? You wont get enough air flow as Grant said at low speeds to warrant the work.
Brake upgrade is far more beneficial with larger rotors and pads. Larger surface area = better heat dissappation.
Posted 08 May 2014 - 01:44 AM
Posted 08 May 2014 - 08:39 AM
someone find me some decent priced brembos and you can have my 4/2 pot setup
Posted 08 May 2014 - 08:57 AM
Posted 08 May 2014 - 09:29 AM
should really be using your gears more!
Using the gears will keep the car more even also as you wont have the weight transfer to the front so much..
how serious are you into the off road scene?
FYI
I got my brakes a bit too hot.. > 750 DegC but then that was doing 10-15 hot laps on the track at Ambient temp of 44+..
and even then it was only after 10+ Laps that i started to get the fade...
Upgrade to 4pots or even just go to 294mm rotors with B4 / XT calipers..
you probably only have 260mm rotors.. or maybe 277's if you have a 97/98 outback
Posted 08 May 2014 - 06:05 PM
I've got the full set of Gen IV SpecB brake discs as mentioned by the guys if you're interested. One requires machining, the other three should be fine.
Posted 08 May 2014 - 07:12 PM
you'll need some calipers for them to be useful unless of course someone with a spec b buys them that is
Posted 08 May 2014 - 07:22 PM
Indeed. Unless he already has/wants to source brake calipers.
Posted 08 May 2014 - 07:25 PM
Minor issue is any brake upgrade will require at least jumping to 16's from the stock Outback 15's. Gen4 GT brakes require minimum 17's.
Pretty happy with my combo of Gen4 GT 290mm rears and XT Forester 294mm fronts. 16's required but these brakes are cheap to obtain.
Posted 08 May 2014 - 08:09 PM
