Howdy guys, need a bit of a hand identifying a problem I've been having..
The car is a gen 2 legacy tt swapped liberty.. What's happening is that occassionly it seems like I'm getting no boost from the secondary turbo, it seems entirely random sometimes it'll be brilliant others it'll be terrible and can go from good to bad and back again in a single trip, still has VoD, just no extra pull after it..
If I was to make an uneducated guess I'd be leaning toward an issue with the exhaust valve for the secondary playing up and probably not opening up the way it should..
Not sure what to start testing in the system (or even how) as I still know bugger all about these things..
So any suggestions, ideas or guides would help me a ton and be appreciated a lot, cheers..
