In the midst of fixing the recent acceleration issue in my sisters car, I removed the TPS thinking it was the MAF... Whoops! Reinstalled it but now I'm now getting a CEL and code P0122/P0122 P (Throttle Position Sensor/Switch 'A' Circuit Low Input).
I've used my cheap code reader to reset the ECU and also disconnected the battery with no luck on either. The CEL is still there.
The car drives and ides fine.
After a stack of research, I believe it needs a .45-.55v signal to be correct at idle but I don't know where to put the pokey things on my multimeter to find the signal. Anyone know? Does the CEL automatically disappear when those numbers are found? Or is there a different recalibration sequence I need to go through for the ECU to detect the throttle position?
