subaru impreza my02 erratic idle/stall at lights
Posted 20 August 2014 - 06:23 PM
Was running fine drove to work in morning all good on way home stalled at lights. When I start back up idles fine for 5 seconds then idle starts Going up and down dramatically.
It is an auto and when pulling up to light's goes to stall only way of saving it is put in neutral snd hold revs up...
Thinking bad fuel as car has sat for 3 weeks on 1/4 tank.
noticed slight pinging on acceleration too.
any ideas?
ive checked vacuum lines.etc.
Posted 20 August 2014 - 08:18 PM
Posted 20 August 2014 - 08:26 PM
Posted 20 August 2014 - 08:30 PM
Sounds like an AFM issue
Posted 20 August 2014 - 08:58 PM
Posted 20 August 2014 - 09:09 PM
I don't think they run an AFM on those engines. To me, it sounds like a vacuum leak. When you take off and drive normally is it fine? Has it thrown a CEL?
Posted 20 August 2014 - 09:16 PM
At idle goes up and down drastically. .and pops out of muffler like massive back pressure.
Posted 20 August 2014 - 10:02 PM
Did you check your spark plug leads?
Posted 21 August 2014 - 12:24 AM
plugs, plug leads cconnections
Posted 21 August 2014 - 06:47 AM
Posted 21 August 2014 - 06:21 PM
Think I can hear a vacuum leak drivers side front of intake mmanifold. There is a vacuum solenoid blue in colour with two ports on it. .no obvious leak but could be it..if not intake off new gaskets.im out of ideas.it just happend all of a sudden.
Posted 21 August 2014 - 06:26 PM
Woukd this effect idle?
Posted 22 August 2014 - 01:57 PM
Posted 23 August 2014 - 01:57 PM
Can these be cleaned as bit pricey new and 2nd hand.
#15 Guest_KONG_*
Posted 23 August 2014 - 02:14 PM
2nd hand.
Where are you?
#16 Guest_KONG_*
Posted 23 August 2014 - 02:29 PM
Find the part number that's written on the sensor and post it up here.
Posted 23 August 2014 - 02:37 PM
Located in smithfield nsw 2164
#18 Guest_KONG_*
Posted 23 August 2014 - 02:39 PM
I'll check the one I have at home and get back to you tonight.
Posted 23 August 2014 - 05:45 PM
