Car won't go into gear!!! Help
Posted 31 March 2009 - 09:54 AM
Posted 31 March 2009 - 09:56 AM
Posted 31 March 2009 - 10:15 AM
Posted 31 March 2009 - 11:26 AM
Posted 31 March 2009 - 11:35 AM
Posted 31 March 2009 - 04:58 PM
95 Gen 2 gx series 1 with rx body kit built 207 on v2 sti heads, running gear, FMIC,twisted ATP GTX3076 Turbo setup
Posted 31 March 2009 - 08:31 PM
Posted 02 April 2009 - 05:56 PM
Posted 02 April 2009 - 07:06 PM
Read the original post again.Common problem,
If it wont engage reverse the first time, Go back to neutral, Clutch out, clutch in. and select 1st gear, then you will be able to go straight back to reverse.
Posted 02 April 2009 - 07:50 PM
do the same for 1st genius
Another trick is have to car in neutral. Do not put your foot on the clutch but slowely select the gear which is giving you trouble. push untill you can feel the syncro try to grab the gear and the car start to move. Hold this position for 10 seconds. Then release.
This will wipe off and sludge or muck that is stuck on the syncro contact surface.
Also works for gears that crunch
Posted 02 April 2009 - 09:23 PM
Posted 03 April 2009 - 12:30 PM
My gen1 and gen3 do that all the time.... always when I'm parking in a carpark and someone is trying to get past meCommon problem,
Posted 03 April 2009 - 12:54 PM
What, so your suggestion for not being able to engage 1st gear is to put it in 1st gear and then take it out and put it in 1st gear? Or are you suggesting to put it in 1st he should put it in reverse, and then put it in 1st, so that he can then solve his problem of not being able to select reverse??do the same for 1st genius
Posted 05 April 2009 - 06:14 PM
I got into my car this morning, started it up, went to put in in reverse and it just grinds. I try to put it in 1st gear and it won't let me put it into gear.
I turn the car off and try and I can put it in any gear.
Anyone know whats going on?
Posted 05 April 2009 - 07:52 PM
