Hey guys,
My left rear shock is leaking pretty heavily. So thought id shop around on the net, but not sure where to start.
Its a 2001 liberty RX.
Could some one point me in the right direction ?
Im guessing you would change them in pairs, so if the fronts arent neccessarily needed should i be changing them aswell ?
Thanks in advanced!
Sauce.
Help with shocks ?
Started by Sauce - RX, May 08 2012 05:57 PM
4 replies to this topic
Posted 08 May 2012 - 05:57 PM
Posted 08 May 2012 - 06:33 PM
A good easy replacement would be a set of kyb's. Otherwise If your looking at different options there are maybe coilovers or bilsteins from a gtb. Are you wanting to keep your existing springs?
Posted 08 May 2012 - 06:51 PM
Hey aek. Thanks for that, don't think ill go coilovers as I don't really think I need them. I'm fine with the current ride height and I'm not looking to take it on the track or spend big money at the moment. Will be keeping my current springs(sports low I think they are)
Kyb's sounds like the go. Is there just a standard set to fit liberty, or do I need to be looking more specific ? I'm guessing it could be worthwhile to do all 4 ?
Posted 08 May 2012 - 07:10 PM
here ya go, part numbers..
front left: 334274
front right: 334273
rear left: 341275
rear right: 341275
you can probably find them sold a set if you ring around or your mechanic can order them in for you
front left: 334274
front right: 334273
rear left: 341275
rear right: 341275
Posted 08 May 2012 - 07:48 PM
Thanks man! Legend!
