Gen 3 Door Lights plug
Posted 19 July 2015 - 11:58 AM
My Rev A wiring doesn't be the harness. And I've been looking at some wreckers for a lib with the plug but I've had no luck.
Does anyone know where I can source OEM plugs or even know what plug it is?
Thanks guys.
Posted 19 July 2015 - 02:09 PM
PM me your mobile number I will send ya a pic of them.
Posted 20 July 2015 - 10:02 PM
Sent from my SM-G920I using Tapatalk
Posted 20 July 2015 - 11:28 PM
I'll post a photo soon. Ahaha.
Posted 21 July 2015 - 01:43 PM
Posted 21 July 2015 - 02:26 PM
Posted 21 July 2015 - 07:52 PM
Posted 21 July 2015 - 10:03 PM
Was the B4 the only model here in Oz that got the door lamps?
Posted 21 July 2015 - 10:55 PM
I might be talking out my arse here but I'm fairly confident that RevE AUDM RX and B4 had the red door lamps. My RevD BH9 didn't but I remember seeing a mate's 2003 Heritage with them. Man, that really doesn't help anyone... lol
Posted 21 July 2015 - 11:23 PM
Ah just curious. I assume the OP's didn't have any at all, hence the question.
Couldn't Pat just wire it (piggyback) into the door switch or whatever tells the car the doors open?
Posted 22 July 2015 - 06:34 AM
Or find the wire that runs down the front a pillar from the centre interior lights
#12 Guest_KONG_*
Posted 22 July 2015 - 08:52 AM
No door wiring on the early models as far as I can tell.
Posted 22 July 2015 - 10:03 AM
I've also got a footwell lighting kit I'm gonna wire in on the same circuit.
Posted 22 July 2015 - 10:33 PM
Holly molly man, I'm in exact same boat here... Got the puddle lamps and footwell lights but not installed yet cos I have no idea how...Yeah Kong basically summed it up, only audm RX rev e had the door lights and a factory mono (and the b4). The wires are no problem, I'll just use the door ajar sensor so it turn on with the door opening, I just need the physical plug that plugs into the lights socket on the inside of the door trim
You MUST do a write up for ppl like me plzzzz....
Posted 23 July 2015 - 09:09 AM
For the plug wouldn't it just be a positive and ground? So couldn't it just be soldered?
Posted 23 July 2015 - 12:57 PM
So I'm still going to wreckers trying to find plugs , and when I get them I'll write up how I get them to work haha
Posted 23 July 2015 - 01:12 PM
Best bet may be Yahoo Japan and try find a wrecking JDM legacy
Posted 23 July 2015 - 06:58 PM
#19 Guest_KONG_*
Posted 23 July 2015 - 07:03 PM
Posted 23 July 2015 - 08:47 PM
Ta.
I just looked up the circuit diagram. The puddle lamps are fed battery voltage and are earthed via each door switch.
For some reason the RH lamp has a diode in the ground circuit, can't really see why it's there? Doesn't look as if can back feed according to the diagram.
For those playing at home, it appears that the puddle lamps are fed through a pair of 25 pin connectors in the bulkhead wiring harness.
Connector B101 is the RH one and the lamp uses pin 19 (LR wire) for batt and pin 23 (BrR wire) for the ground that is switched by the door switch.
Connector B30 is the LH one and the lamp uses pin 19 (LR wire) for batt and pin 23 (RL wire) for the ground that is switched by the door switch. The RL wire carries the diode between the lamp and the switch.
L = Blue
R = Red
Br = Brown
