When thinking about high-tech Subaru features, the fuel tank probably isn't the first component that comes to mind. However, beyond its most basic role of storing and supplying fuel to your vehicle's engine, the Subaru fuel tank features sophisticated engineering designed to keep you and your passengers safe.
The most critical task we face when designing a fuel tank is making it safe," says Yoshiaki Oyamada of the Subaru Engineering Division. "Gasoline is highly flammable when it evaporates, so we must take extra precautions and pay scrupulous attention to the tank's design."
How dangerous is gasoline vapor? We've all seen news reports where cars and trucks have accidentally caught fire while receiving fuel at gas stations. On vehicles with poorly engineered fuel systems, it's possible for evaporated gasoline inside the fuel tank to come rushing out when the fuel tank cap is opened. When air is dry, even a tiny spark of static electricity transmitted by the person opening the cap can ignite this flammable vapor and cause a fire.
"To prevent static-induced fires, the fuel filler lid of Subaru vehicles opens just halfway when you unlock it by pulling the lid release lever inside the car," says Oyamada.
Because the lid only partially opens, the person refueling the car has to open it the rest of the way by hand. Any static electricity transmitted dissipates through the lid, before the fuel tank cap is opened – eliminating the risk of fire. This fire prevention system is a hallmark of the Subaru commitment to safety.
Fuel and fuel vapors move from and to the fuel tank through three lines – one for sending fuel to the engine, one for returning the fuel unused by the engine back to the fuel tank and one for handling evaporative gas (fuel vapors) from within the fuel tank.
Air pressure and increased temperatures cause gasoline to evaporate inside the fuel tank. When evaporative gas is produced, the volume inside the tank increases and the vapor must be released. The vapor is drawn into a charcoal canister to store the hydrocarbons, which are hazardous to health and destructive to the environment.
At the appropriate time, the Electronic Control Module (ECM) on-board computer instructs the solenoid purge valve to open and the hydrocarbons stored in the canister are released to the engine, mixed with intake gas and used as fuel. So recycling the hydrocarbons collected by the canister actually improves your vehicle's fuel consumption while protecting the environment.
When designing a new Subaru model, the fuel system often endures several design changes to accommodate space requirements for other components. For instance, as a result of the all-wheel drive system used on all Subaru models, the Legacy fuel tank features a unique, saddle-shaped design to accommodate the drive shaft for the rear wheels. A state-of-the-art jet pump transfers fuel from one side of the tank to the other to keep the fuel running efficiently though the system.
"Whatever the request, our tank engineers employ the most advanced technology and do whatever it takes to ensure a safe, pleasurable driving experience," explains Oyamada. "It is our challenge – and our chance to showcase our skills."
The Subaru Fuel System: A Tank Full of Technology
Posted 11 May 2009 - 09:06 AM
Posted 11 May 2009 - 08:00 PM
Posted 11 May 2009 - 08:18 PM
Posted 11 May 2009 - 08:22 PM
Posted 11 May 2009 - 09:02 PM
Posted 11 May 2009 - 09:07 PM
Posted 11 May 2009 - 09:14 PM
Posted 11 May 2009 - 09:32 PM
Posted 11 May 2009 - 09:38 PM
Posted 11 May 2009 - 09:47 PM
Posted 11 May 2009 - 10:01 PM
Posted 11 May 2009 - 10:15 PM
Posted 11 May 2009 - 10:51 PM
Posted 12 May 2009 - 09:22 AM
Posted 12 May 2009 - 10:38 AM
Posted 12 May 2009 - 11:24 AM
wouldnt the v2 wrx gearbox be calibrated for v2 wrx sized rim+tyres?
Hmm possible - I am not sure. I'd assume v2 had 205/55/16 though?
Get your Speedo calibrated dude, means taking your cluster out and sending it away. I have only seen a few that have needed doing but it can happen. Last one I seen done though was on an SLR5000
man normal day to day GPS isnt accurate to within a few K's.. take it with a grain of salt.
Carbon Canister shouldn't affect the fuel level reading at all, its an emissions thing. Paul is right, the subaru's use a float and sender unit that moves up and down and sends a low voltage signal.
Hmm. Why would ECU report same speed as speedo is reporting then?
Posted 12 May 2009 - 11:32 AM
Posted 12 May 2009 - 11:36 AM
Posted 12 May 2009 - 11:42 AM
Edit: Posted up some information on this subject.
