I have a 2010 WRX and have recently upgraded (or downgraded) to the 02 4 pots.
When I done the upgrade I took the Pistons out, cleaned them all up, brand new seal kits, shims and pads. Used the same T2 dba rotors I had (1 year old)
So a few months on now, I have a really bad steering wheel shake when I apply the brakes. Inspection shows everything as normal. I then bled the brakes again, and this seemed to have solved the problem. Few days later, it's back.
Any ideas? I'm thinking warped rotors, but 1 year old is a bit iffy, and bleeding the brakes helped, so I'm out of ideas!!
Steering wheel shake - Brake Upgrade.
Posted 08 October 2015 - 02:29 PM
Posted 08 October 2015 - 03:33 PM
either way - it does sound like a disc issue. The bleeding of the brakes (air in the lines) may have changed the resonant freq, or maybe it only happens when they're hot.
Did you bed your new pads in properly ? A good couple of extended hard braking sessions to get them nice and hot, but making sure you didn't stop rolling completely? Stopping completely while you do this bed-in can lead to the deposition problem noted above.
See here for discussion: http://www.stoptech....and-other-myths
Posted 08 October 2015 - 03:56 PM
Putting new pads on used rotors withought machining is a no no. Theyll be worn to suit the 2 pot pads.
Get the rotors machined.
Posted 08 October 2015 - 07:50 PM
That was going to be my next bet, as thats what i originally thought the problem was.
But how would that explain that the shake went away when i bled the brakes?
And i feel machining isn't worth it. I got a quote before of roughly $150, but can get brand new for ~$200
If i can 100% pinpoint that is the reason, i think i will go with some T3's and better pads.
Edit: Sorry missed the first reply.
I did bed them in as you said, not stopping, hard braking etc. I know i did with the rotors when i originally got them, maybe i'm getting confused and didnt do so with the brakes :/
Posted 08 October 2015 - 07:57 PM
I should also note, when i bled the brakes last weekend, a few good air bubbles did come out.
I will try and bleed them again this weekend, but if there are more bubbles, the issue would be a leak and not the disc correct?
Posted 08 October 2015 - 08:18 PM
Posted 08 October 2015 - 08:21 PM
Last time i got rotors machined i think it was $20/corner....
Posted 08 October 2015 - 08:28 PM
The only reason i say about bleeding, is that it did seem to help the problem. In theory if there is air coming through, one or more pistons may not be pushing enough, meaning the pad isn't flat. So if there is air in there again, there has to be another reason how its getting in anyway... Just trying to rule things out that arent costing a deal of money.
Not sure where abouts you are Nick, but the quote around here was $75/corner.
Posted 08 October 2015 - 09:32 PM
Can get new RDA slotted and dimpled fronts for about $150 if that's the case 294mm rotor
Posted 09 October 2015 - 05:43 AM
Posted 09 October 2015 - 08:43 AM
My rears are T2's as well, but stock brakes, so I'd rather stick with DBA on all 4, so once I confirm it IS the rotors, T3 will be my choice!
Posted 09 October 2015 - 10:52 AM
Your quoted price is ridiculous for machining.
Posted 12 October 2015 - 05:50 PM
Reason I say this is I took the pads out of the calipers, pumped the brakes a few times and noticed the Pistons don't all come out at once, or one is a little more stubborn than the others.
Just don't want to buy new rotors to have the same thing happen.
Posted 12 October 2015 - 09:04 PM
Thats normal with the pistons.
Posted 13 October 2015 - 10:36 AM
Pulling the handbrake, slowly, whilst driving caused the same sort of shake. Would this just be the car abruptly stopping, or more so point to the rear?
New front rotors are on order regardless.
Posted 13 October 2015 - 01:47 PM
As above, machine or replace the rotors and Im sure it will solve your problem.
Posted 13 October 2015 - 02:03 PM
I just tend to over think things
Posted 13 October 2015 - 05:20 PM
Are the sliders (if thats what theyre called) moving freely?
My rotors were warped so i replaced them and the pads and now my new rotors are warped cause the slider was jammed so only 1 piston was working properly.
Posted 13 October 2015 - 05:54 PM
Not sure what you mean by sliders.
I've greased the pins on the fronts, the slide pins on the rear seem fine, but I doubt if be getting this much shake through the rear brakes to the steering wheel.
Posted 13 October 2015 - 07:09 PM
nah 2pots but yeah the pins, if theyre fine then that shouldnt be your problem
