Just looking to replace the fuel pump of my 2002 b4. There is one selling $40 on ebay called Felcon fuel pump. Are they good?
Fuel pump choices
Posted 10 November 2015 - 02:02 PM
Posted 10 November 2015 - 02:07 PM
If its a straight replacement a cheap aftermarket one might be ok...but its one area id pay a bit extra and get a higher capacity as a bit of insurance
Last thing you want is a lean out due to an under performing pump
Deutschworks make some good pumps to suit
Posted 10 November 2015 - 02:11 PM
Cheers cubts
Posted 10 November 2015 - 02:13 PM
Dw300 will cover all bases and then some for e85 laterz
Posted 10 November 2015 - 02:32 PM
For yours...yep dw200 would be fine
Decisions decisions
Posted 10 November 2015 - 03:46 PM
Posted 10 November 2015 - 03:52 PM
I had a DW65c which failed in less than 12 months. I think I was just unlucky, but the Kobe fuel pump is the same thing.
I also run E85 so I needed a bit more than the DW200. DW200 would be suitable for a stock B4 though.
Posted 10 November 2015 - 04:22 PM
DW200 isnt a direct fit into a B4, DW65C is. Im running one on my GTB with no complaints to date.
Posted 10 November 2015 - 04:39 PM
I really wish I'd found that out before I modded the fuel pump carrier to accept a DW200
Posted 10 November 2015 - 04:47 PM
DW65C for the B4. I
Posted 10 November 2015 - 05:35 PM
Posted 10 November 2015 - 08:02 PM
This feels like a silly question, but if you put a bigger pump in do you need to retune/reset ECU? Or do the injectors control the flow so you could put whatever size pump in but the injector duty doesn't change, big pump just means no starvation?
Can you change injectors without a tune? 440 -> 550cc
Posted 10 November 2015 - 08:28 PM
Fuel pressure reg takes care of any extra pressure coming out of the pump -- as you say, minimizes chances of fuel starvation due to marginal pump capacity.
Posted 10 November 2015 - 10:14 PM
These figures are purely figurative, I have no idea how much a set injector will deliver for a 20ms spray. Just trying to explain the theory behind it.
Ben
Posted 12 November 2015 - 03:02 PM
