B4 Cruise Control
61 replies to this topic
#41 duncanm
duncanm
    wha' who ?
  • 2,019 posts
Posted 10 January 2023 - 09:38 AM
Is there a light in the instrument cluster?  I think there is only the cruise switch lamp.
#42 allpaw4
allpaw4
    Chief Sparky
  • 2,176 posts
Posted 10 January 2023 - 08:06 PM
H6's with a BFM have a light in the cluster, H4's have a dual filament cruise switch, orange for system power on, green for engaged.
#43 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 24 May 2023 - 10:35 PM
Did you get the cruise control set light in the dash to work
My car is a JDM rev B and doesn't have this set light on the dash, I think only the later cars like rev D had it.
#44 allpaw4
allpaw4
    Chief Sparky
  • 2,176 posts
Posted 26 May 2023 - 05:14 PM
Did you end up finding a copy of the schematics for the Rev B Simon? I know when I wanted the Rev C RX manual, that was all hard copy only, and multiple books. The Rev D/E was the only one covered by the electronic manual.
#45 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 26 May 2023 - 05:33 PM
Not yet, I have the service manual and will use Luke's guide.
I'm  heading off to NSW soon so gunna need it working.
I will start installing this week end.
#46 allpaw4
allpaw4
    Chief Sparky
  • 2,176 posts
Posted 27 May 2023 - 08:02 AM
Oh definitely need it working for a trip like that! Keen to hear if there are any differences with the revision. From what I found, 95% of the wiring was the same between the rev C and the pdf schematics.
#47 duncanm
duncanm
    wha' who ?
  • 2,019 posts
Posted 27 May 2023 - 09:38 AM
have a poke around here.
 https://drive.google...lw_6ATP4k4ZhKZh
#48 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 27 May 2023 - 11:20 AM
Thanks for the link Duncan.
Its some good info in here, its a USA catalogue.
#49 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 28 May 2023 - 01:10 PM
So far I have mounted the CC module, sub switch on the wheel and the CC actuator (made a manifold bracket).
I have all the wiring/plugs etc to sort out and connect up now. Brake and clutch switches sorted.
So I guess you could say I'm getting there.
#50 Barbbachello
Barbbachello
    Touring Bruce
  • 6,487 posts
  • Interests:Docking
Posted 29 May 2023 - 11:50 AM
Sounds like the easy bits. Folding under the dash doing the wiring is a *****. Probably worth taking it out tbh
#51 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 29 May 2023 - 05:37 PM
I had considered doing the dash removal, not really that much extra work.
#52 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 30 May 2023 - 07:19 PM
Not that much extra work, my arse.
Half the car now seams to be pulled apart.
To be fair its been 6 years since it was like this, I had forgotten how much stuff has to come off.
Plus now i have the alarm in the way, with all its wiring.
#53 allpaw4
allpaw4
    Chief Sparky
  • 2,176 posts
Posted 30 May 2023 - 08:44 PM
Mmmm. I don't miss that. Dash out does make for a lot of extra work. But is it worthwhile for the cruise install Simon?
Ben
#54 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 31 May 2023 - 12:15 AM
Ben
Probs only took me 90 mins tops to get it out, so I guess it will be worthwhile.
Plus I had a few other small things to clean up in there.
#55 duncanm
duncanm
    wha' who ?
  • 2,019 posts
Posted 31 May 2023 - 08:56 AM
If you put the cruise control box somewhere on the driver's side, I think you could avoid dash out.
#56 Barbbachello
Barbbachello
    Touring Bruce
  • 6,487 posts
  • Interests:Docking
Posted 31 May 2023 - 09:06 AM
Defs worth pulling the dash imo. 90 mins work to save back ache and to do the wiring nicely would be worth it
#57 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 31 May 2023 - 05:29 PM
Not much free space on the right hand side.
Best just to do it the right way first time.
100% agree
#58 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 18 June 2023 - 08:22 PM
Ok,
So I finished the CC install, powered up the car.
The light works and module clicks when the switch is pressed, I take it down the freeway for a test run.
It works but not very well as the sub switch needs a good clean, fitted a second hand sub switch that I had as a spare, now it works like it was factory fitted from new.
Just got back tonight from a 3K Km trip over the last 4 days, it holds the set speed perfectly and doesn't overspeed when it gets on boost.
#59 allpaw4
allpaw4
    Chief Sparky
  • 2,176 posts
Posted 18 June 2023 - 08:37 PM
That's awesome man, bet you were loving it after doing that many kms. Be nice not having to worry about the typical TT surging at those speeds on light throttle.
Ben
#60 Beckers
Beckers
    OMAR Cubt
  • 3,061 posts
Posted 18 June 2023 - 08:46 PM
Ben
Yeah Ben,
It made the trip much better.
113Kmh is 2650 rpm in 6th gear, this rpm gives me full boost for those uphill sections.
No surging or over speed is a real bonus.
