Engine Suppliers in Melbourne
Posted 30 October 2016 - 07:30 PM
Any recommendations for reputable suppliers in Melbourne.
Thanks.
Posted 30 October 2016 - 07:34 PM
Best bet would be either HCW or GotItRex.
Posted 30 October 2016 - 08:42 PM
Why not just replace the head gasket ??
As per Nick's advise above, maybe add Top Torque to your list also.
Posted 30 October 2016 - 08:43 PM
Posted 30 October 2016 - 08:48 PM
There's water damage and scoring in one of the bores.
Ok, thanks for the extra info.
Sounds like you need a new short motor, reco your heads if required, then put it all together.
Contact Rising Sun Subaru(Noosa) or Ichiban(Sydney) they should be able to help you.
What part of Melb ya from ??
Posted 30 October 2016 - 08:53 PM
I live in Mansfield.
Posted 30 October 2016 - 09:02 PM
Ring Scott @ Ichiban see what he has, see what Ebay has to offer.
Make sure you get an Revision A to C engine, make sure your car is a rev a - c, if its a 2000 model it should be.
Because later ones are a bit different.
Good luck with your time to get it going.
Ps I you post a pic of your car we can check it out for you.
Posted 30 October 2016 - 09:48 PM
It's a BE5C48T 05/00-04/01.
Thanks
Posted 30 October 2016 - 11:03 PM
I hope you get something sorted, sounds like it'll be down to the wire :/
Regards
Posted 31 October 2016 - 07:17 PM
For the sake of one race meet would it hold out with a HG replacement? Or is the bore that far gone?
RSK is NA correct? If not then bin that idea. (I'm not up with those model designations yet).
Posted 31 October 2016 - 07:42 PM
Rsk is twin turboJust re-read this thread, how bad is the scoring on the bore?
Posted 01 November 2016 - 07:25 AM
Dodgy HG swap probably not a good move then.
Posted 28 December 2016 - 09:15 PM
Posted 28 December 2016 - 09:18 PM
And are you still running that engine or have you replaced/rebuilt it??
Posted 28 December 2016 - 10:05 PM
Nice looking GTB there! And a mean set of brakes.
Congratulations on the gongs!
