Problems with OBK
Posted 28 March 2010 - 09:36 PM
Fortunately, i bought the car from a dealer so repairs should come under warranty.
Firstly, after not driving for a little while, it takes ages to start up. (eg. in the mornings, or after work)
Perhaps error code 12 could be the issue (starter signal?)
[url="http://www.youtube.com/watch?v=DOyFVWJ8Q10&feature=player_embedded"]http://www.youtube.c...player_embedded[/url]
It also seems to have a rough idle. Took this vid but not the best sound qual so might be hard to hear... (error 24?)
[url="http://www.youtube.com/watch?v=Y6dGYqFBsXs&feature=player_embedded"]http://www.youtube.c...player_embedded[/url]
Small squeak when depressing clutch? DMF issue? Should i ask if it can be replaced with something different?
[url="http://www.youtube.com/watch?v=MGk8ucN8SzE&feature=player_embedded"]http://www.youtube.c...player_embedded[/url]
And the violent shuddering under acceleration.
On a warm engine, i put my foot down in any gear and it shudders/surges/looses power/knocks/splutters everywhere.
Tried to take some video of this but its hard to get the idea! Sitting in the car it was quite violent and i thought it would of turned out better than it did. Ah well. Hopefully you get an idea
http://www.youtube.com/watch?v=zbdXYENr9Qo&feature=player_embedded
Then there is the knocking sound coming from my footwell - behind the firewall?
It usually happens immediately after taking my foot off the throttle, or when changing down gears but also seems to happen when braking now?
Cant seem to get clear audio of this but can be sort of heard in the previous vid
So i have emailed the dealer whom i bought it off and will hopefully get a reply tomorrow.
I think ill ask to have the following changed;
-Spark plugs
-Spark leads
-Fuel filter
-Knock sensor
-O2 sensor [maybe]
-DMF looked at?
Hopefully knock sensor will fix rough idle, etc.
What do you people think?
For reference, ive already checked for error codes and i got; 12, 24 & 53. Funnily enough, 22 or 28 didnt come up (knock sensor) but that seems to be the most probable issue im getting??
I shall keep you updated and hopefully this will help others with similar problems in the future...
Posted 29 March 2010 - 06:57 AM
Posted 29 March 2010 - 07:20 AM
Posted 29 March 2010 - 08:33 AM
If the miss fire was from a lead, I would expect it to happen when cruising too (well, that is certainly what happened with my car)
Not necessarily, it can only become a problem when the load increases. I've had bad coils before and they were fine on cruising, but as soon as the load increased it would start miss-firing.
Posted 29 March 2010 - 08:43 AM
Posted 29 March 2010 - 08:45 AM
Still waiting for a response from the mob i bought it off for the go-ahead to hand it over to the local suby dealer.
Ill mention all this and hopefully get it all done at once.
So the DMF isnt something i should worry about yet? Or should i, if im able to get it done under warantee?
EDIT: Ninja'd by Chris - cheers mate.
Morgs, sorry to hear you're having some issues with the car!
Yea it is a major pain in the ass but kind of a good thing it is happening now so warranty will cover it
Posted 29 March 2010 - 09:37 AM
Posted 29 March 2010 - 09:57 AM
Posted 31 March 2010 - 08:29 AM
Posted 31 March 2010 - 08:44 AM
Posted 31 March 2010 - 08:46 AM
Dropped it off this morning at the local suby dealer.
Posted 31 March 2010 - 08:52 AM
Posted 31 March 2010 - 09:00 AM
Yea Jase, I would never take it to the dealer on my own accord. I will be getting reimbursed through the dealer warantee so im happy to leave it with them!
Cool
Posted 31 March 2010 - 09:41 AM
I do use Premuim. Didnt think that would affect ignition? One of the error codes i got was 12 (mentioned somewhere above) which is starter signal. Not sure if its fuel related. I know that im getting sweet economy though! Best tank was 8.6L/100kms
Same with my Gen3 RX. Cold starts would take lots of cranking and it'd splutter into life. Mine would run fine otherwise, so I think you probably have some other ignition related problems.
My economy was fantastic - low 9's city driving. Economy was worse on regular unleaded (high 9's/low 10's) but it started fine every time, so i just stuck with that in the end. There seemed to be no noticeable difference in performance either way.
Posted 31 March 2010 - 10:50 AM
Posted 01 April 2010 - 10:50 AM
Got a call back from the local dealer.
I cant even remember all the problems they found.
Some include:
-Ignition leads burnt onto coils
-Spark plugs damaged somehow?
-Seals and bearings or something?
-Air filter is completely black
All up, $1225 worth of parts NOT INCLUDING LABOUR!!!!!!
Holy moly!
It is all going ahead though under warranty.
There are a few minor oil leaks but they will be fixed at a later date but still under the warranty.
Ill post up a full list of details when i get them!
Posted 01 April 2010 - 10:52 AM
Posted 01 April 2010 - 12:35 PM
Morgsy did you inspect this car prior to buying it?
ouch doesnt sound like it.
dealer warranty will only cover so much. did you check if they are covering the whole charge? as there is usually a limit depending on what part of the car need repairs.
Posted 01 April 2010 - 12:40 PM
