Massive loss of power and drivability!
Posted 06 March 2011 - 05:05 PM
What happens is the car will start no problems and has a stable idle but when driving lightly bogs down pretty badly seems more obvious under load like going up hills. If i drive the car harder it seems to stop the car bogging down but is still quite hesitant with the power delivery.
Things that i have tried already, changed the throttle position sensor,crank angle,cam position sensor,knock sensor,o2 sensor, the spark plugs look fine, i've tried different leads.
So at the moment I'm unsure about what to try next apart from taking it in to Subaru which seems like my next step, if anyone else has any ideas as of what it could be I'm open to suggestions.
thanks
Posted 06 March 2011 - 05:30 PM
Posted 06 March 2011 - 05:44 PM
Poor compression?
Posted 06 March 2011 - 05:59 PM
Could it be just a shitty fuel??
Posted 06 March 2011 - 06:05 PM
Posted 06 March 2011 - 06:19 PM
Posted 06 March 2011 - 06:23 PM
Can you have intermittent problems with your fuel pump or fuel pressure regulator?
Posted 06 March 2011 - 06:26 PM
Did you say you have swapped the air flow meter, or cleaned it ?
Have cleaned the one that was on my car and no change then I just put a spare one that i had in with no change, I didn't clean the spare one before it went in but it didn't look dirty
Posted 06 March 2011 - 06:43 PM
Posted 06 March 2011 - 07:04 PM
Cam timing? Weird I know, but could it have jumped a tooth?
Edit: try reading codes anyway.
No splits in the pipework between AFM and throttle body?
Posted 06 March 2011 - 07:05 PM
My old car died going up hills, and lacked heaps of power cause the cat collapsed.
Posted 06 March 2011 - 07:06 PM
Posted 06 March 2011 - 07:29 PM
Posted 06 March 2011 - 07:31 PM
Still worth a look.
Posted 06 March 2011 - 07:40 PM
Posted 06 March 2011 - 08:06 PM
Posted 06 March 2011 - 08:09 PM
He has a world of experience with exhausts.
Posted 06 March 2011 - 08:20 PM
if you could get a hold of some car ramps would be easier to work underneathnot a bad idea a lot of work though
Posted 06 March 2011 - 09:01 PM
Try disconnecting the vacuum line on the pressure regulator while the car is idling, if there is no change in rpm then it is probably faulty. The engine speed should change again once you reconnect the vaccum line.
