Interior light problem
#21
Posted 23 June 2011 - 06:46 PM
#22
Posted 23 June 2011 - 08:18 PM
#23
Posted 23 June 2011 - 08:44 PM
I will try and locate/ fix the box tomorrow and let you know how i go.
cheers
#24
Posted 23 June 2011 - 10:28 PM
OK, so far i have removed the unit and taken the electrical board out of it to inspect it, it has all these little diodes and lines and honestly i dont know what im looking for, nothing on the board seems out of the ordinary. Just wondering if anyone would be able to tell me what i should be looking for to repair? im really lost
any help would be great.
#25
Posted 23 June 2011 - 10:56 PM
I really wouldn't know what to look for either
Good luck
#26
Posted 23 June 2011 - 11:11 PM
#27
Posted 23 June 2011 - 11:21 PM
#28
Posted 24 June 2011 - 11:39 AM
That's not what I meant.just tried wiring up the leds to the door switch, but its a no go... the wires that go to the door switch are only 9v which is to low turn on the lights... back to the drawing board i guess.
can anyone identify the central locking control unit for me? would be a great help.
cheers
You install a NEW 12v wire from the battery, taking it to the input side of a relay, and then the output side goes to the LEDs. You then splice a wire from the door switch going to the trigger pin on the relay. The trigger on a relay can be activated by a very small voltage and current, so 9v is plenty, and then the power for the actual LEDs is drawn from the new wire you ran from the battery.
How many LEDs are you installing anyway? I would think it'd take quite a few to draw enough current to confuse the existing systems.
#29
Posted 24 June 2011 - 12:53 PM
Thankyou for all the help, much appreciated.
cheers
#30
Posted 25 December 2013 - 03:32 PM
#31
Posted 25 December 2013 - 11:31 PM
#32
Posted 26 December 2013 - 05:56 AM
So LEDs strike again!
