Brake upgrade options
Posted 06 July 2011 - 07:56 AM
I don't want to go crazy on them (there's no need) but I'm willing to pay for results. What should I be considering? I'm looking for better feel and better braking performance.
Could I get away with just changing the fronts or the rears? What about slotted rotors, are they worth it or overkill? Braided lines?
Any suggestions appreciated
Posted 06 July 2011 - 08:14 AM
The braided brake lines will give you a better pedal feel.
Posted 06 July 2011 - 09:05 AM
On the cheaper side.. Slotted rotors + new fluid (Works wonders!) and a new set of 4x4 pads might be the go.. i suspect this would also help you with your river crossings n stuff.. clearing the pad surface of dirt and water when braking?
Posted 06 July 2011 - 09:36 AM
Posted 06 July 2011 - 09:52 AM
Better cold braking at low speed, Better fade resistance....etc.
I would make sure the system is in tip top order before deciding to upgrade. Like Ty mentioned new fluid is a great start.
Remember that if you can already get the ABS to kick in without too much trouble, you are approaching the maximum braking that the system will handle.
Ty, I have trouble with how 4 pots will improve fade resistance and feel when looking at specs, the pad and piston area are similar.
I think the best way to improve braking is to increase the mean rotor diameter while keeping the everything else close to stock.
Maybe investigate the larger diameter rotors from the GenIV range.
Also, pad choice makes a huge difference.
The stock brakes on my n/a are really very good and I see no reason to change anything.
You have to be driving like a noob before they start to give up.
edit: just read above post.
Posted 06 July 2011 - 10:04 AM
Posted 06 July 2011 - 11:21 AM
That is why my first question was in regards to pad type.
Posted 06 July 2011 - 12:40 PM
Posted 06 July 2011 - 02:39 PM
Although I imagine some good pads and slotted rotors on this setup would probably see a nice jump in performance.
Braided lines are a definite IMO, much better response and pedal feel.
Posted 06 July 2011 - 03:38 PM
Don't know what pads are there Josh. They are what I got with the car almost 12-months ago and are needing replacement. Good suggestion on the brake fluid Ty ~ I didn't even think of that!
4-pots won't clear my rims. I'm thinking the Gen4 316's will. So that's an option. Can I get away with just changing the fronts or will that not be desirable?
What I want Jase is just to make it a bit better. My Gen2's stock brakes were excellent! The Gen3 I've always felt I really need to 'stand' on them and also brake feel isn't as good. I just want to get it to a sort of "Good" level of performance and feel.
Posted 06 July 2011 - 05:59 PM
QFM HPX pads
RDA slotted rotors.
that is all you will need and will come under $350 easy.
Posted 06 July 2011 - 08:04 PM
If you want to try your wheels over the 316's we can look at Morgans get together day, that's what are on my carThanks for the responses
Posted 06 July 2011 - 09:53 PM
Theyre pretty much 95% all round as I just replaced pads and rotors. Theyve been painted silver / black. Keen?
Or you could just stop being a ***** and buy the front Brembos i'll have for sale.
As stated though by others, the biggest difference I felt was the addition of braided lines.
Posted 06 July 2011 - 10:00 PM
Posted 06 July 2011 - 11:24 PM
As much as I'd love a set of 316's at the front, I'm not sure if the price premium would necessarily yield significantly greater results. Gotta have a think about that...
Adam I reckon they'd fit though I probably should double check. Maybe at the
Posted 06 July 2011 - 11:55 PM
Where did you get the braided lines from mate? I've ways been scared to buy them cos I don't want a dodgy set.
I had mine custom made locally by an ADR approved brake specialist. $180 for the set.
Posted 07 July 2011 - 06:50 AM
pissupmechs day at Morgs place.
No worries!
Cheers! They are going on the list!
Posted 07 July 2011 - 07:26 AM
Posted 29 July 2011 - 06:21 PM
Posted 29 July 2011 - 09:50 PM
Most will have specs.
BTW, when was the Gen5 released??
