problems
#21
Posted 08 September 2011 - 08:49 PM
#22
Posted 08 September 2011 - 09:34 PM
#23
Posted 08 September 2011 - 11:07 PM
it's the oiled K&N's that cause the issue with the MAF.
To check if you can fix it first, buy a can of contact cleaner or better yet MAF sensor cleaner from repco, and drench the f*** out of it.. let it dry and then re-install
#24
Posted 09 September 2011 - 05:37 AM
When i got it back today he told me i should put the factory air box back on it.
should i do that? next month its going back into the same place for a chip and boost control put on.
Is there anything else i should do to it? and will the air pod be ok when this is done?
yeah dont ever put a ECUTEK tune near your car lol,
mines still running rich as ****, i have changed every sensor in the car ,
6 days till it getts a LINK ecu and a VF23 thou
MY02 LIBERTY B4 - LAST DYNO'D @ 375.4KW-ATW 403.5KW-ATW
Next Dyno will be 400+
#25
Posted 27 September 2011 - 05:48 PM
You should count yourself lucky!
I retuned my mates 02 wrx last weekend. It had ecutek and a CAI installed on it.
The tune was so horrible, it was running 12.5afr under full boost and getting lots of knock.
I hate MRT...
Running much better now that i got my hands on it though
#26
Posted 28 September 2011 - 11:56 AM
I hate MRT...
what afr did you tune it to? I would have thought that 12.5 would be not too bad, unless the car was running silly boost?
I know some tuners like to tune to a slightly leaner afr and be conservative with the timing map, while others feed in heaps of timing and then quench it with fuel.
#27
Posted 23 October 2011 - 05:57 PM
A chip was installed and I found out that when it flips over to
the 2nd turbo it has a boost leak and then it has a problem with boost.
goes from 8 to 26 and then 12.
the guy working on it atm says it could be a leak anywhere and/or a switch under
or near the intercooler that wont switch right away.
Anyone have any ideas on what could be wrong?
#28
Posted 23 October 2011 - 10:15 PM
#29
Posted 24 October 2011 - 07:27 AM
It's called "AIDS"
It comes under the broad umbrella of problems that often plague the Subaru twin turbo system.
It may be a slight leak in a vacuum hose somewhere, it may be a faulty one way valve, or it could even be that the solar system's planets aren't in the correct alignment with the third moon of Jupiter. It may very well be that the Feng Shui under your bonnet is not allowing all the bad JuJu to leave.
There is a cure for the AIDS, despite popular belief, however: Single Turbo Conversion. Please consider it.
In the meantime: What chip did you have installed? And it sounds like some sort of waste gate actuator problem. 26psi?? Don't do that too often, or else you'll throw a rod through the block.
#30
Posted 24 October 2011 - 11:11 AM
#31
Posted 24 October 2011 - 02:01 PM
You'll spend heaps for Bill and Kel to find the problem. They are one of the best workshops around and charge accordingly.More problems with my car
It sounds like the actuator for the ECV is sticking or not operating properly. This may be a vac line to the actuator and black box or the ECV is locking up and then opening up when the actuator can get enough force up to push the ECV open.
26psi on the primary is a recipie for a blow-up, in which case a single turbo conversion is the way to go only because the turbos are hard to get and expensive. Although, that said, I think I saw some on Kando Dynamic's ebay site.
I have personally dealt with Bill and Kel (CNJ) as they converted my old B4 to a 2.5STI single conversion. It went very well. Great street setup and did a bit of track work as well.
I have since sold the car and it is still going as strong today as when they first built it for me. It now belongs to forum member Buddylove and is for sale.
You get what you pay for and they generally do great work.
#32
Posted 24 October 2011 - 02:30 PM
I have another plan for AIDS, I call it the sell and move on. When the car gives me trouble in relation to the turbo system, I'll be selling or trading it in, passing the problem onto a dealer or the keen bloke that buys it. By that point I should be able to afford the Gen4 I want however mine runs great at the moment.There is a cure for the AIDS, despite popular belief, however: Single Turbo Conversion. Please consider it.
I've seen DanielB4's car and its quite tidy, if CNJ can figure it out (without major work) that'd be great news.
#33
Posted 26 October 2011 - 04:26 PM
All the problem this time was a dirty solenoid
#34
Posted 26 October 2011 - 06:03 PM
#35
Posted 26 October 2011 - 06:06 PM
i changed checked every sensor on my b4 , and generally speaking its going to be in that solenoid box if any thing goes wrong,
i love my B4 , i just hated the bullshit fault finding proccess on the TT ,
i run a full aftermarket ECU and a VF 23 , never been happier ,
#36
Posted 26 October 2011 - 07:34 PM
Great news.All fixed! get it back tomorrow..
#37
Posted 26 October 2011 - 08:09 PM
#38
Posted 26 October 2011 - 09:01 PM
#39
Posted 05 November 2011 - 07:23 PM
Tuned it closer to 11.3-11.5
As it goes, 12's are best for power but more prone to knocking. And mrt's scaling was so far off they were targeting 9's but getting 12-13... was horrible.
