B4 Conversion - o2 senors
Posted 24 September 2011 - 09:29 PM
So I Just converted my heritage to a EJ20TT got a half cut and did the conversation got a custom exhaust and everything starts and works tho only for a short time.. I have check with the error codes and it shows error code 32. O2 sensor.
see my problem is I only have one connection and that's for the front o2 sensor I can't seem to find the second connection for the other (rear) o2sensor. see I didn't realize there was a second o2 sensor untill I got my exhaust.
this might sound like I'm being lazy but I have spent a few long hours under the car but cant for the life of me find the connection.
do I need to splice into the harness any help would be great...
thanks chris
Posted 24 September 2011 - 10:14 PM
Btw the front one is a fuel/air ratio sensor.
Posted 25 September 2011 - 05:17 PM
Posted 25 September 2011 - 05:54 PM
Posted 25 September 2011 - 07:50 PM
MY02 LIBERTY B4 - LAST DYNO'D @ 375.4KW-ATW 403.5KW-ATW
Next Dyno will be 400+
Posted 25 September 2011 - 09:26 PM
Posted 25 September 2011 - 10:44 PM
When you did the conversion, did you use the B4 wiring loom as well? the plug from memory has 2 black 1 blue and 1 white connector.. either way I know it's got 2 black cause they are the heater wires
#8 Guest_Jesse_*
Posted 25 September 2011 - 10:48 PM
Posted 26 September 2011 - 10:14 AM
Going up to subaru today to find the part numbers thanks all for you help chris
Posted 26 September 2011 - 10:21 AM
I used every little bit from the Donner cut ... I know the front AFS wires are 2 white and one black this connects to a plug near the fuse box in the engine bay.I thought from memory, that error code 32 was the airflow meter.
This is where I'm going crazy. This connvertion sofar has been plug and play. When I pull out theintercooler I will post again with more info hoping To god its there as I hate taking the I/c out.....
Posted 26 September 2011 - 02:32 PM
Posted 26 September 2011 - 05:41 PM
OK so I have made a few calls and found out the jdm legacy bh5 only have an 02 sensor at the front.. no wonder I couldn't find the plug.
I have a jdm e-tune in mine and it has 2 plug and two sensors and its a BH5....
And the front sensor is AIR/FUEL ratio from the engine before the cat. the rear is oxygen sensor after the cat
Posted 26 September 2011 - 07:17 PM
Normally a wideband sensor will give dodgy reading if its positioned pre turbo.
Posted 26 September 2011 - 07:44 PM
Posted 26 September 2011 - 09:17 PM
Posted 26 September 2011 - 10:45 PM
He needs to start from where the sensor is and work backwards: we are not psychic's to tell why a car is having a fault over the net, or mind readers. We can just point in the right direction..
You can lead a horse to water but you cant make him drink it...
Posted 27 September 2011 - 08:32 AM
Posted 27 September 2011 - 12:55 PM
Are u sure its an actual air/fuel ratio sensor? I'm pretty sure at least on the jdmversion its a normal narrowband oxy sensor.Normally a wideband sensor will give dodgy reading if its positioned pre turbo.
tmh983, I think your right as the halt cut was the first release twin Turbo they only had a narrow band o2 sensor on the crossover. jovan, I know what you mean I'm not sure about this but wherent the jdm etunes second generation twin turbos?(Not the for the shape but the engine) sorry I should have said this...I just got a narrow band oxygen sensor and cleaned the MAF Sensor so fingers crossed the problem has gone.. Also got an OBD scaner working now so should be able to clear all the codes showing on the cars system.....
Guys thanks heap for your comments a really big help, fingers crossed it works..
Posted 27 September 2011 - 02:55 PM
What OBD scanner are you using? i've tried a few different ones with my car and none of them work...
