Clutch/Gearbox problem.
Posted 14 October 2011 - 07:33 PM
Over the past few weeks I've notices that my car is shuddering or jerking when I am accelerating mainly in 2nd but it is also happening sometimes In 3rd and 4th. Its quite hard to explain, but it sort of feels like I am 'kangarooing' the car.
It can happen at any RPM.
I'm taking it to get checked out next week, but any advice would be greatly appreciated.
Cheers.
-Jordan
Posted 14 October 2011 - 08:18 PM
Have you changed your gearbox oil?
Posted 14 October 2011 - 08:50 PM
Posted 14 October 2011 - 10:28 PM
Are the symptoms less in the higher gears?
Any strange noises?
Posted 14 October 2011 - 11:58 PM
what do you mean by slack in the drivetrain sorry?
this guy seems to have a very similar problem
http://www.rsliberty...ead.php?t=96325
Posted 15 October 2011 - 06:02 AM
A few people with high km cars have had tailshaft bushings deteriorate and give a shunt/shudder as it spins up or down.
Posted 15 October 2011 - 07:09 AM
Clunking/thumping as you accelerate and decelerate. Feels like something is loose.
Posted 15 October 2011 - 09:18 PM
when i put my foot down, you can tell/feel that the engine is not getting enough petrol, and it is on the verge of stalling, hence it jumping around the place.
Booked in for monday, but my ideas is that it could be:
-Fuel Meter
-Cracked Injectors
-Filters.
any other ideas?
Posted 15 October 2011 - 10:52 PM
Ok So i worked out that its a Petrol problem (derp)
-Fuel Meter
-Cracked Injectors
-Filters.
any other ideas?
I don't know what a 'fuel meter' is.
Never heard of 'cracked injectors'
Blocked fuel filter may cause a lean mixture. Normally a fuel blockage is worse at higher speed/load. Air filter the same but a rich mixture. (more or less)
Let your mechanic figure it out.
Posted 16 October 2011 - 08:56 AM
Posted 16 October 2011 - 10:00 AM
Its one of those problems that is very hard to explain without feeling it.
I actually turned it on and it hasn't happened yet. Its idling in the driveway now but ill give it a proper run in bit. I doubt a problem lasting 2 weeks has just sorted itself out.
Everyone who has driven the car with the problem has said it is a fuel problem though.
Posted 16 October 2011 - 11:44 AM
My fuel pump died not long ago, it's actually really easy to change, we did it at Maroubra Beach parking lot where I broke down the night before hahaha.
Posted 17 October 2011 - 03:16 PM
The coil pack and all these leads had all shat themselves, and needed replacing
Mechanics price to fix ~300
Posted 17 October 2011 - 03:18 PM
Damn... you beat me to the post
Posted 17 October 2011 - 03:21 PM
I'm guessing you left the lube at home?
Posted 17 October 2011 - 03:22 PM
Posted 17 October 2011 - 03:29 PM
I cee's yore problum....OK. So if anyone has this problem in future, here is what it was for me.
These leads had all shat themselves, and needed replacing
U haz no terbu.
Fix STAT!!
Posted 17 October 2011 - 03:41 PM
U haz no terbu.
Fix STAT!!
1004 days till i can drive it legally ....
Posted 17 October 2011 - 03:50 PM
Posted 17 October 2011 - 03:52 PM
set of leads for the suby will only be around $100 a set.
