Nope, it's not the fuel pump.
#21
Posted 22 October 2011 - 01:57 PM
pull a fuel line off after the filter, right after it runs rough and/or stalls, if it doesn't spray everywhere its your pump, the lines should be pressurised even after you turn the car off.
#22
Posted 22 October 2011 - 02:28 PM
Someone suggested burnt out wiring.. took out the fuel assembly again today, the plug going to the fuel pump is all burnt out, looks like its been arcing.. Not a good thing when there is petrol right there?
You're right CodeBurn3r and Marv!
Now, here's another question.. I know I'm gonna be paying out of my ass for a new assembly from Subaru.. anyone know of any good wreckers around Sydney that I could get either a whole assembly, or even just the plug that goes from the pump to the harness?
Thanks for all your help guys, really appreciate it.
Posted 22 October 2011 - 03:23 PM
Post deleted.
The information posted here turned out to be useless!
#24
Posted 22 October 2011 - 03:25 PM
One of the plugs were burnt out! That's what was causing the inconsistency.
Posted 22 October 2011 - 03:39 PM
winner!!!"maybe a split wire going to earth somewhere causing the
ignition orfuel electrics to short out.
#26
Posted 22 October 2011 - 03:52 PM
probably was bad before you swapped pump but you never noticed it.
#27
Posted 22 October 2011 - 04:22 PM
Bush mechanics hahahahaha. But it helps having a sparky (my dad) and a mechanic (my bro-in-law) in the family!
Thanks again for help guys. And yes Benos, you win too.
Posted 22 October 2011 - 04:39 PM
Any suggestions?
Posted 22 October 2011 - 04:54 PM
the pins you cut of from under the dash maybe???Power windows are now
'ed, none work.. I've checked all the fuses and none are blown..
Any suggestions?
#30
Posted 22 October 2011 - 05:41 PM
#31
Posted 22 October 2011 - 07:52 PM
Now I have another issue, i'll copy pasta from GT thread.
Aight, so figured out power window issue was my
'ed alternator.
Get the car going after fuel problem.. start driving to visit mum at hospital.. handbrake light is on? battery light is on?
Pull up at hospital, ABS light turns on, oil temp turns on, check engine turns on..
Car dies right as I pull up. Check voltage on battery.. <8v. Manage to get car started via jump start.. watch voltage slowly drop again.
Alternator is le'ed.
Take my dads car which is parked at hospo to 24/7 KMART. Buy el cheapo kmart battery.. go back to hospital, put new battery in.. hope it retains charge.
No headunit, interior lights, bla bla bla.. Manage to get home [just], battery + handbrake light on again.. Take multi-meter out.. voltage got down to 8v.. the car was barely running.
So, does anyone have a left over alternator from a conversion.. or something spare.. or somewhere to buy one from that would be open tomorrow? (In Sydney).
Cheers.
Posted 22 October 2011 - 08:21 PM
I've got a spare alternator lying around somewhere if you need it.
#33
Posted 22 October 2011 - 08:24 PM
Glad you finally worked out what it is
Already been in contact with Shaz, but if it falls through I'll give you a buzz Shiv! Thanks man.
Posted 23 October 2011 - 08:41 AM
fog lights?
something does not sit quite right with me about all this?
#35
Posted 23 October 2011 - 09:12 AM
They like to throw all sorts of funky lights.
Any Subaru EJ alternator will work. I don't have a spare I'm afraid.
On a Sunday, try Pick'nPayless
#36
Posted 23 October 2011 - 10:12 AM
dude, do you have any home installed car audio?
fog lights?
Yup.. hoping putting a new alternator will fix my problems.. and that I don't need to get an auto electrician to suss out what could be wrong.
Sounds like your alternator is forked.
Just picked one up from Shazboss. Thanks anyway Alex.
Posted 23 October 2011 - 12:52 PM
#38
Posted 23 October 2011 - 12:54 PM
#39
Posted 23 October 2011 - 03:20 PM
Fingers crossed were good to go from now.
Posted 23 October 2011 - 09:07 PM
