blown head gasket?
Posted 17 November 2011 - 11:18 AM
i have a 2000 outback with what i believe has a blown head gasket but im not sure
was wondering if anyone has ever encountered this problem and could help me diagnose whats going on
its a 2.5 liter
thanks!
Posted 17 November 2011 - 11:20 AM
Posted 17 November 2011 - 11:28 AM
Posted 17 November 2011 - 11:51 AM
it does have a small knock but only when the car is first started and it goes away after a few seconds.
i checked the coolant when i did the oil change and it was low...i toped it off and havent checked it sence
no overheating though
Posted 17 November 2011 - 12:04 PM
Posted 17 November 2011 - 12:05 PM
well i gave it an oil change about a week ago and i noticed an oil type substance on the left side of the motor that looked like it was sprayed or shot out from some where
Split CV boot
Posted 17 November 2011 - 05:28 PM
Subarus typically don't often mix oil and water like other cars, believe it or not. (but I have seen it though)
Also, when the engine is running at temp, look into the overflow bottle. If you see bubbles, it may very well be a blown head gasket.
If the engine is slow, sluggish, erratic, it could be.
Best to put a scan tool on it, and take it for a drive if you really suspect it. I had my scan tool on my mate's Gen2 GX which was running like a pig. Temps fluctuated like crazy, yet, the dash gauge stayed rock solid. The gauge sits roughly in the middle from about 70ish to 103 degrees.
Posted 17 November 2011 - 05:50 PM
Posted 17 November 2011 - 10:11 PM
Clean the engine first and then check again. The SOHC 2.5s are know for oil/coolant weeping from the rear of the LH head, due to poor clanping pressure of the head. At first there is minimal symptoms apart from a slight oil leak, this overtime gets worse, and in some cases i have seen coolant drip from this area.
If you have a split inner CV boot, funnily enough the grease sprays out all over where the head meets the block and may be what you are seeing?? CV grease smells burnt often, and is a bitch to clean as its Molybdenum and sticks to everything.
So thats two possible things to look out for.
When you said you needed to top up the coolant, was this in the resovior or the radiator itself? As the resovior will move up and down as the engine cools down/warms up. Which is normal.
As Alex said, just monitor it for the next week or so. And report back
Posted 17 November 2011 - 11:08 PM
Posted 18 November 2011 - 08:52 AM
Split CV boot
i think your rite...because i checked and there is grease coming out of the boot
i didnt see any tears though...could it be loose?
the axel has maybe 3000 miles on it...
but this doesnt explain why its been running rough
Posted 18 November 2011 - 08:57 AM
it was in the resovior after sitting for about 15 min
Posted 18 November 2011 - 09:02 AM
If there is no grease in the current boot, it will start clacking in no time. Perhaps there was some grease left on the axle after the new one was installed and that is what’s flicked up?
At least it’s not the HG! You avoided that well
Posted 18 November 2011 - 09:09 AM
lol yes but it feels slugish and i cant figure out why
Posted 18 November 2011 - 09:35 AM
Has no turbo.
Posted 18 November 2011 - 10:08 AM
Posted 18 November 2011 - 11:16 AM
Posted 18 November 2011 - 11:23 AM
i'll check it out tmrw if i get a chance
Posted 23 April 2012 - 02:46 AM
how hard are they to replace(should i even atempt it)?
i also have a valve cover gasket blown...the plug wire boots are covered in oil, the oil is getting on the plugs and causing a misfire
how hard are they to do?
Thanks for the help!
