DTC P0171, P0172 please help
Posted 30 December 2011 - 02:36 PM
1. Check engine light comes up as the engine starts misfiring, surging, hesitating, stalling, struggle on hill climb, sounded like old VW beetle, white and or black smoke.
2. Runs fine when cruising at 70-130 kph, comes back to #1 below 70 kph, specially in slow traffic, worse in the basement parking.
3. DTC output was P0172 (system too rich) on the first day, then P0171 the next (system too lean).
4. Thoroughly cleaned up MAF sensor, O2 sensor, checked vacuum/intake lines in good condition, no exhaust leak, there is fuel in fuel return line from fuel pressure regulator
5. Pretty much done everything google and yahoo has to offer, except inspecting injectors and fuel pump.
Only things I've done prior to #1
a. added subaru SA718 fuel additive to full tank of BP ultimate.
b. treated with upper engine cleaner, revved as directed......then the nightmare began.
If you came across this same issue before and resolved it, could you please share your thoughts, I need some direction please. Thank you.
Posted 30 December 2011 - 05:19 PM
I know, it's obvious, but it's normally the most obvious things.
Shazza
Posted 30 December 2011 - 05:29 PM
Posted 31 December 2011 - 06:56 AM
Yes i have reset the ECU. the CEL goes away then comes back just after 15mins in idle.
Cleaned up oxy sensor with throttle body cleaner. Is this bad? It didn't have gunk and that whent I took it off.
Sprayed upper engine cleaner in the manifold: temporarily disconnected one of the three vacuum hoses on top, centre,front of manifold. That's where I usually spray it all these years, always with good result but now.
Posted 31 December 2011 - 08:03 AM
thanks for the replies.
spraying the o2 sensor with throttle body cleaner has probably made it worse. they can't be cleaned.
Posted 31 December 2011 - 08:24 AM
so like when on the freeway at 100 for a minute.
the whole lot is bypassed when on cold start.
Hell i even ran my car without an 02 sensor for a while.. just disconnected it
it just makes the car run rich
i would be checking for vac leaks
and resetting ECU
What car btw?
any codes? i.e. the flashing ECU codes..
search connecting the dash plugs and read the flashes..
Posted 31 December 2011 - 08:48 AM
there was an article in the US that says so. maybe that was wrong...maybe i shouldn't of!
it's a $189 replacement from Bursons; a leg from Subaru.
thanks heaps.
is there a way to test (using mulitimetre) O2 sensor? it doesn't show in the service manual.
Posted 31 December 2011 - 09:00 AM
02 sensor only causes problems when the car goes into closed loop mode while cruising AFAIK
and resetting ECU
What car btw?
Car is '02 B4 manual. Code is as per subject P0171/P0172. I've used ECUexplorer + tactrix 1.3. I've reset the ECU multiple times, and after a few minutes, I'm back to #1
Thank you.
Posted 31 December 2011 - 03:27 PM
Thank you.
stand by vac leak then..
cracked pipe, loose connection, doesnt give you grief up high revs but down low all jumpy n rough.
or wastegate issues? but i think vac leaks
what was the catalyst? when did it start.. did you do a engine bay clean or anything?
Posted 31 December 2011 - 05:25 PM
started after i treated it with upper engine cleaner (as per canister direction). few revs to purge the remaining chemicals out, and there it went..CEL + rough idling.
i'll have another look. hopefully i'd find something.
Posted 31 December 2011 - 07:20 PM
wtf?
here we go again.
whinge whinge whinge
Respect your elder members. They've endured many a time stupid questions like yours. They irritate us.
Posted 31 December 2011 - 10:12 PM
Posted 02 January 2012 - 07:36 AM
Posted 02 January 2012 - 08:54 AM
Posted 18 January 2012 - 12:28 AM
Slower Then The Rest
50.CYA
YAMAHA R3 2015
Also tagged with one or more of these keywords: DTC, trouble code, check engine, too rich, too lean
Model Specific →
Liberty / Legacy / Outback →
Engine / Driveline →
Liberty 2012 GT Premium Bank 1 LeanStarted by Davaru, 20 Mar 2018 Check Engine |
