Gen3 engine options
Posted 17 January 2012 - 11:25 AM
my 2000 outback has eather a piston slap or some kind of rod problem not really sure
im just wondering if anyone has had this prob and what they did to fix it
also wondering if i rebuild this 2.5 motor what are some things i could do to inhance it preformance wise
thanks!!
Posted 17 January 2012 - 11:31 AM
Posted 17 January 2012 - 11:42 AM
i would like very much to turbo it but i have no idea what i would need to do
Posted 17 January 2012 - 11:45 AM
Transplant all bits to your car.
Or
If you wanna spend some dosh, got for some STi goodness.
Posted 17 January 2012 - 12:04 PM
what about a legacy gt? aren't they turbo
Posted 17 January 2012 - 12:11 PM
i really dont know
Posted 17 January 2012 - 12:26 PM
if you did decide to go down the path of turbo front clip, you should be able to source one through a JDM breaker locally (not sure where your actual location is).
If you just rebuild then do it with quality parts. Also if you're doing that you could consider upgrading your cams + getting your heads ported / polished to get a bit more poke from it
Posted 17 January 2012 - 12:43 PM
but if i got a legacy gt front clip that would have all that i need
if i cant find a whole front clip but found a legacy gt motor what else would i need to complete it, ecu? idk
also what about the 2.5 turbo out of a baja
Posted 17 January 2012 - 02:35 PM
A 2.5 turbo Baja clip is exactly what you need to be buying.i couldnt tell you
Or a Forester XT clip.
Posted 17 January 2012 - 05:49 PM
Buy a 2002 WRX Front cut , transefe the loom, and all the bits over , enjoy the single turbo!
MY02 LIBERTY B4 - LAST DYNO'D @ 375.4KW-ATW 403.5KW-ATW
Next Dyno will be 400+
Posted 17 January 2012 - 08:56 PM
Posted 17 January 2012 - 09:05 PM
If you're in the US don't even consider a GTB halfcut. They are not compatible with LHD vehicles without a heap of work.
right hand drive twin turbo into left hand drive = don't do it
get a rex, foz or baja clip if you go down that road
Posted 18 January 2012 - 12:12 AM
least some one agrees with me
Posted 18 January 2012 - 01:04 AM
i think this is what im gona try and do
what else will i need besides the motor? will my tranny work with a 2.5 turbo?
the computer im assuming?
Posted 18 January 2012 - 07:28 AM
Posted 18 January 2012 - 07:55 AM
Posted 18 January 2012 - 09:30 AM
if you get a halfcut/front clip you'll get the engine, gearbox, wiring, ecu etc and make sure you also ask for the rear diff. as luke said, you'll need a GT bonnet or front mount
i work at a bodyshop and theres only one parts place around that we get our parts from called LKQ.
ive seen the clips they sell and some arent pretty! they usually dont come with a motor eather
so i think if i do this i'll buy it all separate.
Posted 18 January 2012 - 09:44 AM
to get you started
http://www.ebay.com/...ht_11296wt_1396
http://www.ebay.com/...#ht_3332wt_1163
Posted 18 January 2012 - 09:54 AM
Posted 18 January 2012 - 09:59 AM
