Posted 11 March 2012 - 08:44 PM
Just hit 95,000kms and due for another oil change and thought I'd do the UEC as well. One question, where do I spray it?!
Posted 11 March 2012 - 08:46 PM
Posted 11 March 2012 - 08:50 PM
Also morgs there is a diy on ozfoz for it but would also expect the same process on most, if not all, subaru.
Posted 11 March 2012 - 08:51 PM
I've also heard that on turbo models it should be sprayed into the throttle body? Thoughts on that?
Posted 11 March 2012 - 08:52 PM
Posted 11 March 2012 - 08:56 PM
That's where the boost gauge is T'd into. Does that matter or should I pull it off the T instead of the manifold?
all the ports are fine to spray into, the one i mentioned is by far the easiest and most convenient to spray while car is running.
Posted 11 March 2012 - 08:58 PM
Posted 11 March 2012 - 09:01 PM
Posted 11 March 2012 - 09:04 PM
Posted 11 March 2012 - 09:08 PM
Posted 11 March 2012 - 09:11 PM
If its really dirty, I use an old toothbrush to give it a scub.
Posted 11 March 2012 - 09:59 PM
A good point to bring up though Alex, easy enough for someone to forget, the more that people read this, the greater the chance they will rememberThis may be a captain obvious point, but you do know to spray the UEC BEFORE you change the oil, and not after.
Posted 12 March 2012 - 04:03 AM
I am guessing it will blow decent smoke rings? God knows how long it has been since it was done. I would say the service before I bought the car, but that is only an assumption.
Posted 12 March 2012 - 05:55 AM
Posted 12 March 2012 - 06:30 AM
Mine still puts on a pretty good show!
Posted 12 March 2012 - 08:28 AM
I've driven 15,000kms since purchase and haven't done it yet. Not sure when the last UEC was.
Posted 12 March 2012 - 08:34 AM
Posted 12 March 2012 - 08:38 AM
Posted 12 March 2012 - 08:44 AM
trooves5000>12,500
i have some double coated ones in the fridge.
nom.
