Rewiring Seat airbags - Need some info
Posted 25 August 2012 - 02:11 PM
MY95 Liberty Wagon (Silver)
(With lots of Extras to come)
Posted 25 August 2012 - 02:39 PM
Posted 25 August 2012 - 03:18 PM
Guessing here, but I think it doesn't matter which way they're wired up.
You Thought WRONG
But on topic i'll have a look on monday in the diagram to tell you what wire is what....
Posted 25 August 2012 - 03:24 PM
#5 Guest_KONG_*
Posted 25 August 2012 - 04:21 PM
Your air bag light on the cluster will be showing while it is disconnected.
When you connect it back up the light should disappear.
Posted 25 August 2012 - 06:50 PM
Posted 25 August 2012 - 06:58 PM
Cheers Jovi. I'd love to get it in the car today but I guess I'll have to wait. By the looks of it I'll have to pull the cover off the seat to see the air bag and go from there. Can I put the seat in the car and not connect the air bag up for now?
You sure can use the seats with out connecting them. but if your car didnt come out with air bags in the seats from factory you may or may not need to change the module for the air bag control....
Posted 25 August 2012 - 07:34 PM
Posted 25 August 2012 - 07:53 PM
Posted 25 August 2012 - 10:27 PM
cut accidentally
Posted 25 August 2012 - 10:53 PM
Posted 25 August 2012 - 11:26 PM
Posted 26 August 2012 - 08:37 AM
Hahaha
Posted 26 August 2012 - 09:24 AM
The seats in for now and I'll have a look at wiring up the drivers side next week
Posted 26 August 2012 - 11:16 AM
If it doesnt support it and you connect it or connect it back wards you will trigger the airbag either in the seat or unlucky all depends how the system works..or you can be lucky and just have the airbag light on all the time just depends as i said how the system is set up...
My advice to you would be if you have all the factory wiring from both cars then use it, if you dont just bolt the seats in and leave it alone, or pay someone to connect it for you if you are un sure...unless you are 100% sure on what you are doing....if you get it wrong it will be a more costly repair then if you pay some one to do it....
But on monday when i get to the work shop ill look up the diagram for the GD wrx for ya to tell you which is positive which is negative triggers to the airbag it self...
Posted 26 August 2012 - 01:46 PM
which car are you wiring them into? As there is a main control module as well in a gen3 liberty its just above the shifter under the ash tray... if you add side air bags it also needs to be wired to the main module as well. If not they will not work, and you need to know if the module supports side airbags as well...
Both the wrx and MY06 forester seats have airbags in the same spots. The passenger side was fine and the drivers side is to, but my dilema is that the owner of the seats before me has cut the actual airbag wiring halfway along it and I was thinking 'no worries just solder then back up, positive to positive negative to negative" but there are no lines on either wires to distinguish the 2. I have both seats in now with the passenger seat all wired up and working fine. But the drivers side is still disconected and yes i am getting the airbag light.
Heres the wire on the drivers side.
Both seats in with only the passenger side hooked up
Posted 26 August 2012 - 02:54 PM
do what you will but its at your own risk.
0415 522 512
Posted 26 August 2012 - 03:51 PM
You may find that the cut wire is a section of wiring with a plug at each end. One to plug into the body harness, the other end to plug into the back of the air bag module. If so, maybe you could use that.
+1 for not repairing the wiring.
(having said that, there is a tolerance in the resistance that the control unit 'sees')
Posted 24 July 2013 - 12:59 PM
So I still havent fixed this, thinking about just wiring in a resistor and taping the rest of the wiring so it "looks" like it is conected. I really dont care if one air bag didnt go off. The year before my car never had them and they are still safe to drive around in.
