Cleaning and restoring headlights
Posted 09 September 2012 - 01:47 PM
Anyway I was wanting to know peoples personal preference on the way to clean your headlights inside and out. What products to use and any tips I may need and what is the most effective in lasting the longest instead of having to do the process monthly etc.
I have a 2001 RX liberty and my headlights are looking slightly average and want to get the best out of them besides buying a new set.
Thanks in advance.
Posted 09 September 2012 - 03:40 PM
Here's a DIY I did a little while ago on restoring headlights -
http://www.subyclub....ht-restoration/
Posted 09 September 2012 - 04:35 PM
If they still look dull after doing the restoration, you may have to pull the headlights apart to clean the inside.
Posted 09 September 2012 - 05:07 PM
Posted 09 September 2012 - 06:48 PM
Posted 09 September 2012 - 07:03 PM
We only used the one grade of sandpaper in the DIY but I know people who have started with a rougher wet and dry then gotten finer and finer as they went along. Very good idea.
You might have to do it again but it's like washing a car. It's going to get dirty again because you use the car. If you have a spare $1000, you can buy a brand new set of headlights but I'd rather spend <$50 on decent cleaning gear and use some elbow grease doing it myself
I like to give my cars a good detail (claybar/buff/polish/sealant, etc) every six months and I do the headlights at the same time.
Posted 09 September 2012 - 07:12 PM
Posted 09 September 2012 - 07:20 PM
Posted 09 September 2012 - 07:28 PM
Posted 09 September 2012 - 07:40 PM
But I personally won't recommend any method which requires scrubbing of headlights using sandpaper. It removes the protecting UV coating of the headlight. Though it might look to have worked after you've done it, exposure to sunlight, cold weather etc will in the long term result in the return of yellowing to the lens.
Different people will have different results. Morgs and Adam's obviously look to have worked thus far. If you're car isn't garaged, that could determine how successful it is LONG TERM.
Ideally you want to use something non-abrasive. So a good buffing pad would be a better option. But keep buffing to a minimum.
Let us know how you go!
Posted 09 September 2012 - 07:43 PM
Posted 09 September 2012 - 08:33 PM
Posted 10 September 2012 - 05:31 PM
The dulling is due to oxidation. Not just dirt, although dirty lenses will suffer the effects of UV radiation faster. If you are getting oxidation (and subsequently dulling/clouding) then the UV protection has already failed. So you may as well resort to polishing them up any way you can.
Headlights cop a battering. They're on the front of the car getting all the road grime, they get the worst of stones,bugs etc, they get hot from the inside during use, and are exposed to the elements all the time. Its little wonder they suffer.
Their are businesses that specialise in restoring headlight lenses, and they actually use a special coating, not just a polish.
Im happy to accept that once the factory UV protection is gone, Im going to have to give them a buff up every 6 months or so.
Posted 10 September 2012 - 05:49 PM
Posted 22 September 2012 - 04:24 AM
Posted 22 September 2012 - 08:06 PM
Posted 23 September 2012 - 07:43 AM
Posted 24 September 2012 - 12:20 PM
Posted 24 September 2012 - 12:35 PM
Posted 24 September 2012 - 07:42 PM
If you check the stamped/printed info on the globe mounting all new globe should read H7U etc, the U stands 4 uv filter.
