Brain scratcher, low rpm vibration when stopped.....
Posted 09 January 2013 - 05:27 PM
Shift to Neutral and the vibration is gone.
Car idles smooth in both Park and Drive, no erratic movement of the tacho.
New leads, spark plugs.
No error codes.
New engine / trans mounts.
IACV and TPS both working perfectly, have tested with multimeter.
Car drives perfectly smooth and fuel consumption has not changed.
Transmission fully flushed and operation as normal.
Thoughts?
Posted 09 January 2013 - 05:38 PM
Approx 675 rpm in Drive and 750 rpm in Neutral. Within manufacturers specs.
Posted 09 January 2013 - 05:43 PM
Posted 09 January 2013 - 05:48 PM
Posted 09 January 2013 - 05:56 PM
Posted 09 January 2013 - 07:24 PM
Posted 09 January 2013 - 09:57 PM
Posted 10 January 2013 - 08:06 AM
May be a torque converter issue.
I was thinking the same. I know little about torque converters bar the basic operation.
When you accelerate off from the lights, the very first split second of acceleration, the car (feels like driveline) vibrates and then all smooth and normal.
Posted 10 January 2013 - 08:14 AM
Posted 10 January 2013 - 03:26 PM
Posted 10 January 2013 - 03:41 PM
It ended up being a broken engine mount.
Fine in neutral, but in drive at the stop lights it would vibrate like crazy.
Just another idea.
Posted 10 January 2013 - 03:50 PM
Brand new mounts went in with the engine 20K ago. Visually looked them over and they still look mint, but I will undo and jack up the engine to double check.
Posted 10 January 2013 - 03:59 PM
Posted 10 January 2013 - 05:08 PM
Posted 10 January 2013 - 05:42 PM
Yet to do any research, but is the torque coverter a serviceable or replaceable item?
Posted 10 January 2013 - 08:17 PM
Can be replaced but they are a sealed unit. A specialist can machine them open, rebuild, then weld shut.is the torque coverter a serviceable or replaceable item?
Posted 10 January 2013 - 09:23 PM
Posted 11 January 2013 - 10:00 AM
I have fitted aftermarket front driveshafts at roughly the same time
Common problem with aftermarket driveshaft and auto trans, i had them same thing happen.
Replaced the driveshafts, problem went away for a little bit (1 year) but now has come back.
Heaps of people have had the same issue over on http://www.subaruoutback.org/forums/
Posted 11 January 2013 - 01:14 PM
Looks like i'll swap the fronts to the rear as the rear are still oem.
Cheers.
