Do they have the plug, but just no lights?
Theres nothing wired behind the doors for the puddle lights. I've had the door trims off multiple times and never found anything. If you have the lights, you could just run the wires back into the cabin (have fun getting through the that rubber boot thing) and just twist/solder it into the two connectors I put in under the steering column for the footwell lights. Unless the wires are already run into the main door harness and its just a case of splicing into them? I'll have a look at the workshop manual when I get time.
