First of all, I have to disagree, a sealed box will always have a smaller size (if the design is any good), which is why most car setups have a sealed box.
There are also 2 main different sorts of ported boxes out there. One is the tuned length port, with a set length of tube placed in the box (and its placement is also key), and the other being some form of bandpass. The idea behind porting is to flatten the frequency line. Tune it so the low points are enhanced, and the high points are lowered. I have seen speaker boxes that have twin ports (and they sounded amazing), but the bloke who built them was a sound engineer, so I figure thats probably out of our range here.
The general rule with a sub box, is the bigger the volume, the better it will sound. But volume is a premium in a vehicle. So bear in mind how much of your boot needs to remain 'usable'.
Do a little research and figure out which way you want to go. I would stick with a sealed box for a car personally, but it is purely a personal choice (I like having a boot I can use).
There are various computer programs out there that will allow you to input all the data from the subs datasheet (which would have come with it in the box if it was new, or get the model number of the sub and go searching for them on the net). Its worth mentioning that if you get the specs wrong, the design will be wrong, and will not sound as good as it could.
It will then take that data and spit out the optimum box size. There should also be a set of parameters you can change to give it maximum dimensions in the case of a restricted measurement (like the height of the box when it is in the boot). With those measurements, it will likely make one larger than optimal, in exchange for making another smaller.
You will more than likely find that you will not get the optimum size box to fit for a 15" sub, and keep anything resembling a usable boot. Expect most of the forward part of your boot to be dedicated sub storage.
Looking at those spec sheets, make sure you get a 2 ohm stable amp (preferable 1 ohm stable even, being the sub is only 1.67 ohm). You'll cook the internals of the amp after a while if you dont. Note the max input power on the sub too - 400Wrms. You can feed it with more, but you'll cook the voice coil of the sub over time if you over-power it (ever had a speaker thats scratchy when you push it in and out? thats the varnish flaking off the coil due to excessive heat and scratching on the side of the magnet).
I know this sounds like heaps of info to take in, but if you look at the spec sheets and design your audio system by whats written rather than what the sales person is trying to sell you, you will end up with a nice sounding, well balanced system that doesnt give you problems in the future like dead amps and dead speakers.
