gearbox swap?
Started by jack_keaka, Mar 04 2014 06:45 AM
8 replies to this topic
Posted 04 March 2014 - 06:45 AM
Does anyone know if a 5 speed from a 99 GX will fit into my 02 RX?
Thanks,
Jack
Thanks,
Jack
Posted 04 March 2014 - 07:02 AM
I'm 99% sure that they will be the same gearbox.
Posted 04 March 2014 - 07:06 AM
But yes it will fit.
Posted 04 March 2014 - 07:49 AM
Yeah will be fine, aslong as they both have the same amount of bolt holes.
Posted 04 March 2014 - 08:28 AM
Id check the ratio. Have the feeling the GX will be 3.9 where as the RX wil be 4.11
Posted 04 March 2014 - 08:52 AM
Thanks guys!
What is the effects of that ratio difference?
I have a GX lined up for about 1k to transfer some parts. And I know the gearbox on this is immaculate.
Posted 04 March 2014 - 08:55 AM
Gota swap the rear diff also, otherwise you will burn out your centre diff.
It probably would rev slightly lower at speed.
Posted 04 March 2014 - 02:09 PM
Hmmm doesn't sound worth it tbh. I just want a new gearbox so I can put the car on the market.
It won't sell for anything more than 1.5-2k with the gearbox on it's way out. I figure I fix it for a few hundred and sell the car for 4-5k
Cheers for the info guys.
Posted 04 March 2014 - 02:23 PM
rear diff swap is under an hours job
much easier than a gearbox swap
