No brake pedel after fitting upgraded brakes
Posted 23 May 2014 - 06:43 PM
We bled the air but no air came out, the brake pedal still goes to the floor.
Any suggestions?
#2 Guest_KONG_*
Posted 23 May 2014 - 06:51 PM
Are they on the right side with the nipple at the top?
Posted 23 May 2014 - 06:55 PM
Posted 23 May 2014 - 09:36 PM
It would also pump up for a little bit then it you left it for a bit it would go straight to the floor.
Posted 23 May 2014 - 10:37 PM
If the master is able to move fluid through the nipple when you are bleeding then you may have air trapped further upstream or the master cylinder has carked it.
I suspect the latter.
NEVER allow the pedal to go to the floor when bleeding, only use half the pedal travel or you risk stuffing the master.
Posted 23 May 2014 - 10:38 PM
I hope this isn't the case for you Rob!
Posted 23 May 2014 - 10:42 PM
How do i go about removing air from the upper part of the system?
The pedal wasn't pushed all the way, as dad was doing the pushing he's a mechanic.
In theory should the master cylinder be able to cope with the extra 2 pots?
Factory had single pot fronts and rears, i now have 2 pot fronts and single rears.
Posted 23 May 2014 - 10:51 PM
One front caliper of mine has the same amount of pistons as the whole car used to and mines all good. So id say yes it can cope it it
Posted 23 May 2014 - 10:52 PM
Yeah that's what i thought, Dad keeps trying to convince me that it wont cope.
Posted 23 May 2014 - 10:53 PM
Master will be up for it.
Double check you put the calipers on the correct sides, Try a gravity bleed, Check for leaks at the master and report back.
I had a bog stock gen3 outback 2.5 master running brembos and it was fine.
Posted 23 May 2014 - 10:54 PM
Rob Brad (meady8) also put GTB front brakes on his gen 2 in the last couple of days might be worth talking to him (im pretty sure he has fitted them anyway)
Posted 23 May 2014 - 10:56 PM
Will do!
i know the fronts are right, just cant recall about the rears.
Its bugging me and i cant check right now!
Yeah i spoke to brad, he had no problems.
Posted 23 May 2014 - 10:59 PM
Bit of an upgrade though
#14 Guest_KONG_*
Posted 23 May 2014 - 11:00 PM
forking huge yo!
Posted 23 May 2014 - 11:03 PM
yeah but 4 pots look cooler....
Posted 23 May 2014 - 11:06 PM
I wont despute that
Bigger rotor = better heat dispersion, exactly what i wanted
#18 Guest_KONG_*
Yup!
You're shit Rob. Fix your braques.
Posted 23 May 2014 - 11:10 PM
Ill fix your braques
Posted 24 May 2014 - 04:08 AM
