If this is to be believed - http://legacygt.com/...ems-120477.html - then it sounds like a blockage in the heater core (or feed to/from it).
This is consistent with some of your results - where everything working ok with the core bypassed..
Posted 10 December 2015 - 06:44 AM
Posted 13 December 2015 - 08:42 PM
i had some issues with an aftermarket thermostat - it was opening properly, but i could never bleed all the air out of the system. in the end swapping to a genuine one fixed it.
Posted 14 December 2015 - 09:12 AM
I only read the first post. There is some truth but TBH I don't believe most of it.
The OP's issue may still be a blocked or partially blocked heater core.
Posted 14 December 2015 - 11:07 AM
I suspect this is the function of the little hole + dingleberry on the OEM thermostat.
Posted 14 December 2015 - 11:20 AM
Posted 14 December 2015 - 05:45 PM
no - that makes no sense.
I think you're saying if the impeller shaft has play - and the impeller wobbles, then the pump vanes won't work.
Problem with that theory is, I think, that the pump would be leaking through the shaft like a biatch.
Cold lower hose means thermostat not opening.
Posted 21 December 2015 - 03:32 AM
Posted 21 December 2015 - 10:22 AM
Take a read at this:
http://www.autospeed...esting&A=110478
I had a bloke with a vehicle (not a Subaru) that would blow a radiator apart at least once a year and sometimes it would blow fairly new hoses. Tried everything, caps, thermostats etc., even tried a lowering the cap pressure from 13psi to 7 psi by fitting a lower pressure cap.
One day it's in for repairs and I end up replacing the pump. The old one looked OK from the impellor side, just had a small leak.
He phones a few days later asking "What did you do my car?" I'm thinking the worst so I ask him what he means. "It's running better and seems to be using less fuel. Did you tune it?" No I say, just replaced the pump and a leaky hose.
Pondered over this for a few years until a mate told me about a bloke who hand finishes custom water pump impellors (he also showed me this pump test) and conducts efficiency test on the pumps before he lets them out of the shop. Said mate had fitted one to his 350 Chev and experienced a similar thing, better running and no overheating in traffic.
Moral of the story, don't underestimate the water pump.
Posted 05 January 2016 - 01:59 PM
Hi again. I hope you guys had a good new year's and Christmas.
Just a quick recap.
When bleeding the air out of the cooling system, when I still have my bleeding funnel in the reservoir above the turbo (turbo tank), and the thermostat is opening for the first time, the lower radiator hose warms up for just a little while. Then this happens:
And I discovered something else, when I was flushing the cooling system. When I poured water into the top hose, the water came out through the thermostat housing on water pump - so far so good. Then I clogged the outlets to see if the water can flow freely through individual outlets, and I discovered that the water doesn't flow through the outlet number 1. This one goes to engine block through the oil filter housing. (See attached image below)
Untitled.png 3.18KB 6 downloads
Can anyone recommend a good diagram of the EJ20HDWAJE waterways?
Or just give me your feedback, as always, it's greatly appreciated.
Yep, nope - it's not the water pump. You're right. The noise and leak would give this away.
Posted 15 January 2016 - 08:20 AM
UPDATE:
My lower hose finally warms up.
Replacing these seems to have helped the proper coolant circulation, but now I noticed the coolant level fluctuates a lot. There are two parts to this "problem" I would like to be considered:
1.) I was bleeding the air out of the system, and the water level in my funnel was going up and down a lot:
2.) After I bled the system, I put the turbo tank cap back on, I let the car idle for a while, and the water level kept on rising and falling, all the way to the point where the coolant started to pour out of the overflow tank.
My suspicion is this might be a malfunctioning coolant reservoir pressure cap? The cap on the overflow tank may be too weak? I am wondering, what's the correct pressure reading that's supposed to be on both the radiator and the turbo tank caps? This is EJ20H engine.
Posted 15 January 2016 - 07:28 PM
Problem solved. I replaced both pressure caps and bled the system thoroughly.
Whoever made it all the way here; here are some hints to look out for when you're experiencig similar behaviour as described above:
1.) pressure test your cooling system.
2.) check all hoses for kinks/breaks
3.) flush the cooling system as well as the radiator
4.) take off your intercooler and flush the heater core separately; bypass it if need be.
5.) make sure your termostat opens and closes properly.
6.) Don't be cheap and buy new caps, thermostat gasket and hose clamps. (Use common sense)
7.) Bleed properly. Can't stress this enough.
8.) above all, don't loose hope!
P.s.: Thanks Duncanm, I found your comments most helpful.
P.s2.: The heater core is still clogged. That should now be pretty straight forward... Thanks to all who participated.
Posted 16 January 2016 - 07:46 AM
Nice work Pod glad you got it sorted....
Posted 18 October 2016 - 10:21 PM
Posted 19 October 2016 - 06:13 AM
glad to hear its sorted -- what a marathon of an effort.
Model Specific →
Liberty / Legacy / Outback →
Electrical/Electronics →
Radiator cooling fans manual switch with indicator lightsStarted by Tristan, 03 Aug 2016 cooling, radiator, fans and 1 more... |
