HELP! what is this noise?
ej22 noise help
3 replies to this topic
#1 zacsuby
zacsuby
  • 4 posts
Posted 02 January 2017 - 05:06 PM
Hi everyone,
My 1996 gen 2 liberty gx started making this noise today (see the youtube video linked) and I can't work out what it is exactly. It's like a rattly whir that goes with the revs and sounds like its coming from the back of the motor? If anyone has heard it before or has any ideas of what to check to determine what it is please let me know!
#2 duncanm
duncanm
    wha' who ?
  • 2,019 posts
Posted 02 January 2017 - 05:30 PM
sure its the rear?  Sounds a bit like an alternator pulley bearing or similar.
Pull your accessory belt off to check.
#3 zacsuby
zacsuby
  • 4 posts
Posted 02 January 2017 - 07:09 PM
Hey,
Thanks for the suggestion. Pulled off the accessory belts and sound was still there unchanged. Thinking it could be a bearing under the timing belt cover so that's probably the next point of call. She's at 171,000 kms anyway so maybe she'll get an early belt and pulleys change.
Cheers for the advice and if anyone else has 2c to add I'm all ears!
-Zac
#4 duncanm
duncanm
    wha' who ?
  • 2,019 posts
Posted 02 January 2017 - 07:38 PM
Suggest you attack the problem with a mechanics stethoscope (length of hardwood or similar -- like a broomhandle). Press it against various parts of the block and bits (water pump, for example) to see if you can pinpoint the location a little better before pulling it apart.
Also tagged with one or more of these keywords: ej22, noise, help
