I have a frs 6spd transmission in my 97 imprezza and I'm having allot of rear end issues. First it's open from factoryou so I blew that up pretty quick. So I welded it. Then I broke the welds. So I brought it so a shop and they welded it professionally. Then I check under the car a few days later and there's a big ass hole in the diff cover. I just opened it up and it's not good. The carrier has split in half and all the crown gear bolts have loosened right off and the bolt are what smacked the cover. I've looked online and can't find and lsd's that are tough enough for under $1000. I'm wondering of the 2002-07 carriers will fit or even the whole diff but with my axles? I'm not sure how to go about this because if I just throw in another welded diff then it's just going to break again. What would you guys do?
In need of help with my rear end. Rwd suby
Started by Westonw14, Oct 23 2016 11:58 PM
Differential Help Rear end Broken Rwd Rear wheel drive Imprezza Sti Bolts Frs
2 replies to this topic
Posted 23 October 2016 - 11:58 PM
Posted 27 October 2016 - 07:07 PM
get a bigger diff...
IFS toyota diffs can be shortened, shave 6mm off the side the extension bolts to and fit an oil seal. Then you just have to mount it and work out drive shafts etc.
See here for this dude's efforts with his British V8 with IRS using a toyota diff
Then get bigger drive shafts...
Then get a stronger subframe (which would need to be heavily modded)...
Posted 27 October 2016 - 07:29 PM
Sti r180 gear is the strongest bolt in stuff
So sti diff/hubs and shafts gd style onwards
A gd sti rear subframe will bolt right in also if you wanted a slightly stronger subframe
R200 probably would be the best setup for a rwd
But lots of custom modification
Also tagged with one or more of these keywords: Differential, Help, Rear end, Broken, Rwd, Rear wheel drive, Imprezza, Sti, Bolts, Frs
Model Specific →
Impreza / WRX / STi →
Engine / Driveline →
Differential compatibility!?Started by Sweezyboi, 26 Oct 2019 subaru, NA, Differential, LSD |
Tech: The basics →
Brakes →
AMG Big Brake Kit... adapters?Started by timslib, 08 Apr 2019 6 pot, brembo, sti, bbk |
Tech: The basics →
General →
Subaru Liberty (all models) STi part listStarted by Liberty, 03 Nov 2017 subaru, liberty, sti, sti options |
Tech: The basics →
Naturally Aspirated →
HELP! what is this noise?Started by zacsuby, 02 Jan 2017 ej22, noise, help |
Suby Club Community →
General Discussion →
Complete fa20 gear box on my ej18 in imprezzaStarted by Westonw14, 20 Oct 2016 Fa20, Ej, Rear wheel drive, 6spd and 6 more... |
